    Apr 2014
    London
    Hi. I've noticed that when choosing a resolution to encode in HEVC in SUPER, it has only a number of preset resolutions, and when I try to encode a widescreen movie, it gets stretched. I was wondering is there a way of setting a custom resolution, like in x264 in SUPER if you click "more" twice it comes up with the dialog box where you can enter a custom resolution. If no, then do you know of any other free gui HEVC encoders (other than DiVX)? Thanks!
  2. DECEASED
    Jun 2009
    Heaven
    Give a try to Hybrid.
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    If you don't mind using Avisynth script for input, you can use Simple x264 Launcher. Lot's of other ways like ffmpeg, Virtualdub and AviUtl, but Hybrid would be easier I think.
    Apr 2014
    London
    Thanks a bunch! It's exactly what I needed!
