I'm really hopping someone can answer this question...
I'm converting and burning BD from movies taken on the net.
I'm using both AVS Video converter and Nero to do so. After it is converted, I use IMGBurn to finish the disc.
To convert, I really like AVS Video converter because it has functions I prefer, Nero doesn't do editing as nice as AVS does. My problem is that, when converting with AVS, the more it goes, the more the audio separates from the video. It is going out of sync. Nero doesn't do that. It's stays in sync.
My question is: Can I use BDMV files/folders from Nero and transfer them into the AVS BDMV folder so that my converted, in sync, movie reflects the AVS template? And witch one should I move?
I'd really appreciate you help on this one. I've seen a lot of people that have sync problem when burning big MKV files.
Thanks a lot.
Alan M.
Use avchdcoder or bdtoavchd to convert mkv to bluray /avchd. Burn with imgburn.
OK but if I like to mount or edit DVD's and Bluray discs with the picture of the disc and all the kit, I won't be able with these two software won't I ?
