  1. I hope im in the right section on this one. I have a bin/cue file that is for a vcd but the problem is, if I burn it, I dont have anything to watch it on. I was wondering if there was a way I could extract and or convert to a avi or some file type so that I could watch on my computer? Is this possible? Thanks for any help!!
  2. If you burn the vcd you should be able to watch it on your computer without any problems.
    A software dvd player would give the best result but you could use windows media player. Just open the folder "mpegav" and you should have one or more .dat files. Those are the video files.
  3. Will I be able to see it even though I dont have a DVD drive on my computer?
  4. No, you dont need a dvd drive.
    Good luck!
  5. WOW! I never new that, I'll slap it in the burner and let ya know how it turned out thanks!
  6. I use VCDGear v3.07b12 to convert cue/bin's to mpeg's.
