Hello
There's a radio show whose first half is available as an MP3 audio file while the second half is available as an MP4 audiovideo file.
I'd like to combine both into a single MP4 audiovideo file.
I was thinking of using ffmpeg.exe to create an MP4 file from the MP3 + JPG file with the exact same audiovideo parameters as the MP4 file, and use "My MP4Box GUI" to join the two files into a single MP4 file.
Does it look like a good idea?
Thank you.
PS: Here's what MediaInfo says about the two input files:
Audio
VideoCode:General Complete name : C:\first.half.mp3 Format : MPEG Audio File size : 9.50 MiB Duration : 10mn 22s Overall bit rate mode : Constant Overall bit rate : 128 Kbps Writing library : LAME3.99r Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Duration : 10mn 22s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 9.50 MiB (100%) Writing library : LAME3.99r Encoding settings : -m j -V 4 -q 3 -lowpass 17 -b 128
Code:General Complete name : C:\second.half.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 118 MiB Duration : 19mn 41s Overall bit rate mode : Variable Overall bit rate : 835 Kbps Tagged date : UTC 2014-04-17 08:37:51 Writing application : Lavf55.19.104 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 19mn 41s Bit rate : 700 Kbps Width : 848 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.069 Stream size : 98.5 MiB (84%) Writing library : x264 core 140 r2377M 1ca7bb9 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 19mn 41s Duration_LastFrame : -11ms Bit rate mode : Variable Bit rate : 128 Kbps Maximum bit rate : 800 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 18.0 MiB (15%)
I must be using the wrong settings in ffmpeg, because the two MP4 files aren't compatible so can't be joined with either MP4Joiner or My MP4Box GUI
Turning MP3 into MP4 video:
Converting MP4 to identical settings found in first file:Code:INPUT Complete name : C:\first.half.mp3 Format : MPEG Audio File size : 9.50 MiB Duration : 10mn 22s Overall bit rate mode : Constant Overall bit rate : 128 Kbps Writing library : LAME3.99r Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Duration : 10mn 22s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 9.50 MiB (100%) Writing library : LAME3.99r Encoding settings : -m j -V 4 -q 3 -lowpass 17 -b 128 ffmpeg.exe -loop 1 -i speaker.png -i first.half.mp3 -shortest -vf scale=640:480 -c:v libx264 -tune stillimage -c:a copy radio.show.first.half.mp4 OUTPUT Complete name : C:\radio.show.first.half.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 13.3 MiB Duration : 10mn 24s Overall bit rate : 178 Kbps Writing application : Lavf55.35.101 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High 4:4:4 Predictive@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 10mn 24s Bit rate : 45.2 Kbps Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:4:4 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.006 Stream size : 3.36 MiB (25%) Writing library : x264 core 142 r2409 d6b4e63 Encoding settings : cabac=1 / ref=3 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=2.00:0.70 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.20 Audio ID : 2 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Codec ID : 6B Duration : 10mn 22s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 9.50 MiB (72%)
Code:INPUT Complete name : C:\second.half.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 118 MiB Duration : 19mn 41s Overall bit rate mode : Variable Overall bit rate : 835 Kbps Tagged date : UTC 2014-04-17 08:37:51 Writing application : Lavf55.19.104 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 19mn 41s Bit rate : 700 Kbps Width : 848 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.069 Stream size : 98.5 MiB (84%) Writing library : x264 core 140 r2377M 1ca7bb9 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 19mn 41s Duration_LastFrame : -11ms Bit rate mode : Variable Bit rate : 128 Kbps Maximum bit rate : 800 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 18.0 MiB (15%) ffmpeg.exe -i second.half.mp4 -shortest -s:v 640x480 -c:v libx264 -tune stillimage -c:a libmp3lame -b:a 128k -r:a 48000 radio.show.second.half.mp4 OUTPUT: Complete name : C:\radio.show.second.half.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 103 MiB Duration : 19mn 41s Overall bit rate : 731 Kbps Writing application : Lavf55.35.101 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 19mn 41s Bit rate : 595 Kbps Width : 640 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.078 Stream size : 83.8 MiB (81%) Writing library : x264 core 142 r2409 d6b4e63 Encoding settings : cabac=1 / ref=3 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=2.00:0.70 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.20 Audio ID : 2 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Codec ID : 6B Duration : 19mn 41s Duration_LastFrame : -1ms Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 18.0 MiB (18%) Writing library : LAME3.99.5
I noticed this error when creating the second MP4 file:
After removing this wrong switch, the two files aren't identical:Code:-tune stillimage
- The first file: aspect ratio 4:3, sample frequency 48000Hz
- The second file: aspect ratio 1:1,77, sample frequency 44100Hz
