  1. I have read aloy of the posts and have made many VCD's. I am interested in making some with entrypoints like a DVD but am not sure if it is simple. What tools do I need and is it simple? Any help would be greatly appreciated... Thanks
  2. Member adam's Avatar
    Sep 2000
    you can use vcdimager which is free or you can use I-Author or video pack 4.0, both of which are not free and are actually quite expensive.
    Regardless of which program you use look through the Author link to your left for guides on them and most of the info you need to use vcdimager can be found on this forum...just do a search.
