Hi
I loaded an mpeg into tmpenc, it plays fine in windmedia but when I try to process the file or use tools, it shows an illegal bitrate message. ]
Why is this so?
Also any way to rip the rest of a VCD dat when part of it is damaged? The VCD plays fine to the end, with some glitches. But using CDR and various tools the part after the damaged part cannot be accessed.
Hlp pls
Results 1 to 1 of 1
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Changing AC-3 Bitrate (Problems with AC3gain)
By dabas in forum AudioReplies: 3Last Post: 30th Jan 2010, 14:55 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
