hi, i a HDR-XR150 handycam which records videos with the following information
Complete name : --------------------------------------
Format : BDAV
Format/Info : Blu-ray Video
File size : 296 MiB
Duration : 1mn 50s
Overall bit rate : 22.4 Mbps
Maximum Overall bit rate : 24.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=13
Codec ID : 27
Duration : 1mn 50s
Bit rate mode : Variable
Bit rate : 21.2 Mbps
Maximum bit rate : 22.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.410
Stream size : 280 MiB (95%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 129
Duration : 1mn 50s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -80ms
Stream size : 3.38 MiB (1%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 1mn 50s
i am done editing with vega pro 12 and now i want to render the video
i want an output exactly same as the input, not more nor less bitrate/quality.
but in vegas when i choose "AVCHD 1920x1080-50i" render template, and after even setting bitrate to 21,999,616 bps, my output video would have bitrate of approxiately 15414067 bps. how can i get same bitrate?
Results 1 to 1 of 1
