hi there
hi have just d/led resident evil and blade2 . the pictue is very good quality but the audio is out of sync is it posisble to but it in sync without disturbing the pic. quality? if so can you explain for me please i really want these movies on vcd formate .
thank you
dave
you are saying that you want the video in a vcd format right? so what format of the video just now? i dont know any software to fix this off hand just now but let me have a look tomorow its gettin late here.
Mikey :lol: -
You mean you downloaded crap
Please specify the "out of sync" problem. Is audio faster / slower than the video or is there just an audio / video delay? Also it might be necessary to post the file properties here and which tools you are willing to use to convert to MPEG.
it seems to be a video delay , because the audio comes out fist before the video. i'm using vdub , tmpgenc and nero or vcdeasy to burn.
audio format:
mpeg layer 3,56kbits
24,000 hz stero
video format
352x288
24 bits, 35031 frames
12,500 frames/sec
ms-mpeg4 v3
hopefully this will help with the answer .
thanks -
Don't know about resident evil, But I do know Blade 2 is OK, apart from the usual bad frames.
Is the AVI in sync ? and only goes out of sync after conversion ?, and by any chance is it Nero that has cause the sync problem, because the AVI was not converted to a fully compliant VCD mpeg ?
Load AVI into Vdub, select Video > Scan Video stream for errors.
Then select Video > streaming, and audio > streaming and SAVE AS
Save out another copy of the movie (1 min or so)
Now load new movie into TMPGEnc Next hit the "load" button and load a "VCD template" PAL/NTSC
Hit run and stop after a few minuets and check the output.
If there is still a problem, you need to select Settings > Advanced > Source range , From there you can use audio gap correct +/-
At a guess I think you have not made a fully compliant VCD, and Nero is converting it, and will cause this problem -
thats the way i d/l it from kazza , i want to fix the problem with the audio before i start making my vcd . i did d/l blade2 aswell and the samething happen, audio starts before the video . the quaulity seems pretty good with both movies thats why i'm trying to fix the problem ...hopefully
thanks
dave
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 16:12 -
audio problems...............
By themediaman in forum Video Streaming DownloadingReplies: 6Last Post: 25th Dec 2010, 17:43 -
Problems with Audio
By fi3ryfalc0nZ in forum Software PlayingReplies: 3Last Post: 7th Dec 2009, 18:23 -
Audio Problems
By macuser1960 in forum ffmpegX general discussionReplies: 9Last Post: 26th Feb 2008, 14:46 -
Problems w/Audio
By itsmevic in forum AudioReplies: 1Last Post: 9th May 2007, 00:53
