  1. My system setting- Pentium III 1000mhz, 768 ram, 100gig HD , ATI Radeon 8500dv!
    I hope someone can help me because this is really starting to piss me off! I am backing up my vhs tapes to dvd.. here is my problem! I would capture my vhs tapes using ATI TV/VCR.. the format that I save to is Mp2 (which is the dvd setting).. After I finish .. I used TMG encoder and encode the mp2 into mpg(mpeg2) So Far So Good.. Here is the problem.. I would make a project in DVDit and When I try to go and burn the project onto DVD it would tell me that I must have a sequence header with every GOP header! ??? It would work if I didn't encode with TMG, but I need to encode it with TMG for the project won't fit!
    Will Somebody Please Help!
    Dec 2001
    Moscow
    I understand that TMPGEnc has a DVD template which matches the DVDit requirements. Do you use it for encoding?
