Hi.
I have Blu-ray Burner LG WH10LS30, was formatting BD-RE media which is pain in the ass, it lasted like an hour and stacked at 98%, so had no choice did PC restart.
Drive doesn't lights up anymore.
I guess it need to be re flashed(???)
Any help?
go in to the drives settings and uninstall the drive. restart you computer and see if it will reinstall the drive.
Yeah, uninstalling it in Device Manager and rebooting should do it, assuming the drive isn't dying. If not, shut down, open the case, unplug the drive and boot up, then shut down. Re-plug the drive. Reboot.
Again, assuming the drive is okay, that rewritable is done for. It happens eventually.Pull! Bang! Darn! -
Which software were used??
*** Now that you have read me, do some other things. ***
