    Apr 2012
    My World
    I use these code
    LoadPlugin("F:\Program\megui\tools\avisynth_plugin\VSFilter.dll")
    raw = DirectShowSource("F:\raw.mkv", fps=23.976,
    audio=false, convertfps=true)
    logorgb = aviSource("F:\Logo RGB.avi")
    logoalpha = aviSource("F:\Logo Alpha.avi")
    raw
    clip1 = raw.trim(0,2231)+trim(2232,2252).overlay(logorgb,0,0,logoalpha)+trim(2253,88000)
    fin=clip1
    return(fin)
    but this code is problem when my logo fading
    now I have 2 file Raw File (mkv file) and RGBA File (avi file).
    and i want to slove problem from my old code
    what should i do.
    please show reference or example code
    my eng is very bad sorry for these
    Thank for help.
  2. We probably need to see your logo and alpha videos.
    Here's an example script using a single image (cropped from your sample image):
    Logo.png:
    function RgbFade(clip vid, float fade)
        RgbAdjust(vid, r=fade, g=fade, b=fade)
    logo = ImageSource("logo.png")
    alpha = ImageSource("logo.png").Invert().Animate(0,100, "RgbFade", 0.0, 1.0)
    ColorBars()
    Overlay(logo, 0, 0, alpha)
    Trim(0,100)
    Add "Return(alpha)" just after creating alpha to see what the alpha video should look like.
    Apr 2012
    My World
    sorry for confuse. but i dont understand old topic
    i will explain my problem by image.
    This is my code
    LoadPlugin("F:\Subtitles\Program\megui\tools\avisynth_plugin\VSFilter.dll")
    raw = DirectShowSource("F:\Subtitles\Work\Subtitles\Hoshizora e Kakaru Hashi BD\ Hoshizora e Kakaru Hashi - OP.mkv", fps=23.976, audio=false, convertfps=true)
    oprgb   = DirectShowSource("F:\Subtitles\Work\Subtitles\Hoshizora e Kakaru Hashi BD\OP RGB.avi").ConvertToRGB32()
    opalpha = DirectShowSource("F:\Subtitles\Work\Subtitles\Hoshizora e Kakaru Hashi BD\OP ALPHA.avi").ConvertToRGB32()
    raw
    clip1 = raw.trim(0,4)+trim(5,272).overlay(oprgb,0,0,opalpha)+trim(272,88000)
    fin=clip1
    return(fin)
    what should i do .
