right this is my prob i am using the guide DVD to high quality SVCD conversion guide when i put in the frame rate i choose 25fps for pal thats fine when cce is finished encoding the video i use pulldown thats also fine i get a nice little movie but when i attempt to burn the mpeg using nero its saying that i have encoded the file with frame rate of 29.9fps what the hell is goin on here? just to double check my self i put the frame rate to 23.3fps then used the pulldown and it still gave me 29.9fps! i just dont understand why it keeps changing the frame rate.
is there anyways round using pulldown program after encoding in cce? if not give me some suggestions i am frustrated here.
Mikey :lol:
what is 3:2 pulldown?
You want PAL, so do not use pulldown.exe. -
but when the file is encoded through cce its saved as .MPV and that cannot be multiplexed with tmpgenc. when i use pulldown it changes the file extention to .M2V do you think that i might get away with changing the file extention manually?
ill try and let you knowMikey :lol: -
truman ive done a little reading on that 3:2 pulldown. and i found that its only for making NTSC videos. sorry for the waste of time mibby i should do a little reasearch my self next time before asking for help.
Mikey :lol:
Change frame rate. Audio don't match with Video...?!
By SB4 in forum Video ConversionReplies: 2Last Post: 25th May 2011, 14:55 -
how to change frame rate on staxrip?
By VistaXP in forum Video ConversionReplies: 6Last Post: 6th Apr 2011, 14:13 -
Help with understanding when to change frame rate
By mlaran in forum Video ConversionReplies: 3Last Post: 22nd Feb 2010, 10:11 -
Scriptable tool to change AVI frame rate metadata?
By FurrTheBear in forum Video ConversionReplies: 4Last Post: 8th Jan 2010, 01:43 -
CCE keeps on trying to change my frame rate?
By friedtofublocks in forum Video ConversionReplies: 17Last Post: 14th Dec 2007, 05:21
