HI,
I am using the Latest version of GOM Player as most people are using it.But it plays DVDRip avi files smoothly with default speed. But all other formats, for example, mkv, wmv, mpeg, mp4, m4p …etc. Does not play smoothly.it stops in the middle for fractions of a second and then starts and the whole high definition video watching experience is a mess I mean is very bad. Actually a slow motion video would be better. The support of this particular media player I mean GOM Media Player told me about sending info about problematic videos Filters. Though I don’t know what Filters do but the Filter Info Below is of a movie which does not play smooth video.Before that I want to say that it plays DVDRip avi files smoothly but all other file types(mkv,wmv,…) it plays but not smoothly.
[Ver. 2, 2, 56, 5183(EN)]
*** DIRECTSHOW FILTER LIST ***
1. Default DirectSound Device
2. Video Renderer
3. Gretech Audio
4. Gretech Video
5. ffdshow Audio Decoder
6. Gretech Source Filter
*** VIDEO INFO ***
Input Type : AVC1(GVC)
Input Size : 1280 x 720
Output Type : RGB32
Output Size : 1280 x 720
FrameRate(Frame/sec) : 0.00 (29.97)
*** AUDIO INFO ***
SampleRate(Sample/sec) : 44100
BitRate(Bit/sample) : 16
Channels : 2
KBitRate(KBit/sec) : 74
The Filter info of a movie which GOM Player played smoothly is given Below,
2. Video Renderer
3. Gretech Audio
4. Gretech Video
Someone also told me to give DXDiag log,so it is given below,
System Information
Time of this report: 4/9/2014, 07:10:59
Machine name: MOON-F5FBEC5233
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.130704-0421)
Language: English (Regional Setting: English)
System Manufacturer: MICRO-STAR INTERNATIONAL CO., LTD
System Model: MS-6340
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Athlon(tm) XP 1700+, MMX, 3DNow, ~1.5GHz
Memory: 504MB RAM
Page File: 338MB used, 890MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file s3gnb.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: The file es1371mp.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: S3 Graphics ProSavage 8A26 (Microsoft Corporation)
Manufacturer: S3 Graphics, Inc
Chip type: S3 ProSavage KM133(TM)
DAC type: S3 SDAC
Device Key: Enum\PCI\VEN_5333&DEV_8A26&SUBSYS_00000000&REV_03
Display Memory: 8.0 MB
Current Mode: 1024 x 768 (32 bit) (85Hz)
Monitor: Samsung SyncMaster 750s(T)/750Ms
Monitor Max Res: 1280,1024
Driver Name: s3gnb.dll
Driver Version: 6.14.0010.0012 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 4/14/2008 15:42:06, 397056 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: s3gnbm.sys
Mini VDD Date: 4/14/2008 08:04:34, 166912 bytes
Device Identifier: {D7B75DD3-C966-11CF-BC63-0A20A2C2CB35}
Vendor ID: 0x5333
Device ID: 0x8A26
SubSys ID: 0x00000000
Revision ID: 0x0003
Revision ID: 0x0003
Video Accel: ModeMPEG2_C ModeMPEG2_A
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Creative Sound Blaster PCI
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1274&DEV_1371&SUBSYS_13711274&REV_08
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: es1371mp.sys
Driver Version: 6.01.6499.0001 (English)
WHQL Logo'd: No
Date and Size: 11/21/2007 21:15:44, 37376 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCCC
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Creative Sound Blaster PCI, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 10:15:38, 59520 bytes
| Driver: usbd.sys, 8/9/2013 05:55:06, 5376 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 4/14/2008 10:48:02, 52480 bytes
| Driver: kbdclass.sys, 4/14/2008 10:09:48, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 10:43:22, 40840 bytes
+ Microsoft USB Basic Optical Mouse v2.0 (IntelliPoint)
| Vendor/Product ID: 0x045E, 0x00CB
| Matching Device ID: hid\vid_045e&pid_00cb
| Upper Filters: Point32
| Service: mouhid
| Driver: mouhid.sys, 8/17/2001 18:48:00, 12160 bytes
| Driver: mouclass.sys, 4/14/2008 05:09:48, 23040 bytes
| Driver: point32.sys, 8/1/2011 15:56:42, 40936 bytes
| Driver: wdfcoinstaller01009.dll, 8/1/2011 15:56:42, 1461992 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 1.3 GB
Total Space: 8.0 GB
File System: NTFS
Model: QUANTUM FIREBALLlct20 20
Drive: D:
Free Space: 0.7 GB
Total Space: 10.0 GB
File System: NTFS
Model: SAMSUNG SV4012H
Drive: E:
Free Space: 0.7 GB
Total Space: 5.0 GB
File System: NTFS
Drive: F:
Free Space: 0.3 GB
Total Space: 6.5 GB
File System: NTFS
Drive: G:
Free Space: 2.4 GB
Total Space: 15.0 GB
File System: NTFS
Drive: H:
Free Space: 3.0 GB
Total Space: 7.2 GB
File System: NTFS
Drive: I:
Model: TEAC DVD+RW DV-W58E
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/14/2008 10:10:48, 62976 bytes
System Devices
Name: Intel(R) PRO/1000 GT Desktop Adapter
Device ID: PCI\VEN_8086&DEV_107C&SUBSYS_13768086&REV_05\3&61A AA01&0&40
Driver: C:\WINDOWS\system32\DRIVERS\e1000325.sys, 8.10.0003.0000 (English), 8/20/2008 14:18:42, 171152 bytes
Driver: C:\WINDOWS\system32\e1000325.din, 10/30/2007 13:35:22, 2878 bytes
Driver: C:\WINDOWS\system32\NicCo2.dll, 1.02.0000.0000 (English), 8/7/2007 10:28:34, 28272 bytes
Driver: C:\WINDOWS\system32\NicInstG.dll, 9.10.0005.0000 (English), 8/28/2008 17:37:54, 41080 bytes
Driver: C:\WINDOWS\system32\e1000msg.dll, 9.08.0000.0000 (English), 12/14/2007 12:06:06, 121440 bytes
Name: S3 Graphics ProSavage 8A26 (Microsoft Corporation)
Device ID: PCI\VEN_5333&DEV_8A26&SUBSYS_00000000&REV_03\4&9AE DED5&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\s3gnbm.sys, 6.14.0010.0012 (English), 4/14/2008 08:04:34, 166912 bytes
Driver: C:\WINDOWS\system32\s3gnb.dll, 6.14.0010.0012 (English), 4/14/2008 15:42:06, 397056 bytes
Name: Creative AudioPCI (ES1371,ES1373) (WDM)
Device ID: PCI\VEN_1274&DEV_1371&SUBSYS_13711274&REV_08\3&61A AA01&0&48
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (English), 4/14/2008 10:41:58, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.5512 (English), 4/14/2008 10:42:44, 129536 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.5512 (English), 4/14/2008 05:46:38, 141056 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/14/2008 05:15:16, 60160 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/14/2008 05:49:42, 146048 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (English), 4/14/2008 05:15:16, 49408 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/23/2008 19:36:41, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\es1371mp.sys, 6.01.6499.0001 (English), 11/21/2007 21:15:44, 37376 bytes
Name: VIA CPU to AGP Controller
Device ID: PCI\VEN_1106&DEV_8305&SUBSYS_00000000&REV_00\3&61A AA01&0&08
Driver: C:\WINDOWS\system32\DRIVERS\VIAAGP1.SYS, 5.01.0000.3442 (English), 7/2/2003 00:00:00, 27904 bytes
Name: VIA Power Management controller
Device ID: PCI\VEN_1106&DEV_3057&SUBSYS_00000000&REV_40\3&61A AA01&0&3C
Driver: n/a
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_1A\3&61A AA01&0&3B
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/14/2008 10:15:36, 20608 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.6437 (English), 8/9/2013 05:55:08, 144128 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 15:42:10, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 10:15:38, 59520 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_1A\3&61A AA01&0&3A
Name: VIA PCI to ISA bridge
Device ID: PCI\VEN_1106&DEV_0686&SUBSYS_00000000&REV_40\3&61A AA01&0&38
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/14/2008 10:06:42, 37248 bytes
Name: VIA Bus Master IDE Controller - 0571
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_00000000&REV_06\3&61A AA01&0&39
Driver: C:\WINDOWS\system32\DRIVERS\videX32.sys, 7.00.7000.0294 (English), 2/11/2010 11:59:18, 13976 bytes
Name: VIA CPU to PCI bridge
Device ID: PCI\VEN_1106&DEV_0305&SUBSYS_00000000&REV_81\3&61A AA01&0&00
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:52 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:52 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 02:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:52 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:52 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:52 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:52 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 02:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 02:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 15:42:18 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 15:42:18 17920 bytes
dpnet.dll: 5.03.2600.6311 English Final Retail 11/2/2012 07:02:42 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:39:22 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:39:20 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 15:42:20 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 02:00:00 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:00:00 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 15:42:42 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 02:00:00 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/23/2008 19:36:41 35328 bytes
gameenum.sys: 5.01.2600.5512 English Final Retail 4/14/2008 10:15:30 10624 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 82432 bytes
system.dll: 1.01.4322.2503 English Final Retail 3/8/2014 07:25:46 1232896 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 2113536 bytes
mfc40.dll: 4.01.0000.6151 English Beta Retail 9/18/2010 11:53:25 954368 bytes
mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 18:33:55 978944 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 15:42:12 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 15:41:50 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 15:41:52 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 15:41:54 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 15:41:58 35328 bytes
mpg2splt.ax: 6.05.2600.6333 English Final Retail 1/2/2013 11:49:10 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 15:42:00 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:41:54 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 15:42:04 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 15:42:04 279040 bytes
qdvd.dll: 6.05.2600.6169 English Final Retail 11/3/2011 20:28:36 386048 bytes
qedit.dll: 6.05.2600.6512 English Final Retail 2/5/2014 13:55:04 562688 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/14/2008 08:51:34 733696 bytes
quartz.dll: 6.05.2600.6333 English Final Retail 1/2/2013 11:49:10 1292288 bytes
strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 13:00:21 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 15:42:44 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 15:42:44 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 15:41:56 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 15:41:56 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 15:41:56 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 15:41:56 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 15:41:56 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 15:42:44 154624 bytes
mswebdvd.dll: 6.05.2600.5857 English Final Retail 8/5/2009 14:01:48 204800 bytes
ks.sys: 5.03.2600.5512 English Final Retail 4/14/2008 05:46:38 141056 bytes
ksproxy.ax: 5.03.2600.5512 English Final Retail 4/14/2008 10:42:44 129536 bytes
ksuser.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:41:58 4096 bytes
stream.sys: 5.03.2600.5512 English Final Retail 4/14/2008 05:15:16 49408 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/14/2008 10:09:52 5376 bytes
mspqm.sys: 5.01.2600.5512 English Final Retail 4/14/2008 10:09:52 4992 bytes
mskssrv.sys: 5.03.2600.5512 English Final Retail 4/14/2008 10:09:54 7552 bytes
swenum.sys: 5.03.2600.5512 English Final Retail 4/23/2008 19:36:41 4352 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 15:42:44 118272 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 15:42:02 1428992 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 15:42:44 30208 bytes
msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 22:11:44 17920 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 15:42:12 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.03.4530.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.6333
Gretech ASF Source Filter,0x00200000,0,1,GSFU.ax,1.00.0000.0011
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.03.4530.0000
Gretech MPEG Source Filter,0x00200000,0,1,GSFU.ax,1.00.0000.0011
ffdshow Audio Decoder,0xff800001,1,1,ffdshow.ax,1.03.4530.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.6333
WS ScreenCapture,0x00200000,0,1,ScreenCaptureFilter.a x,5.05.0003.0003
LAV Splitter,0x00400001,1,1,LAVSplitter.ax,0.60.0001.0000
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.6333
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.6333
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0 001.0001
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.6333
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600. 6076
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6 333
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000. 4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.6333
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
ATI MPEG File Writer,0x00200000,1,0,atimpenc.dll,11.06.0000.5052 7
ATI MPEG Video Decoder,0x005fffff,1,2,atimpenc.dll,11.06.0000.505 27
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0052
Mpeg2Dec Filter,0x00600000,1,1,Mpeg2DecFilter.ax,1.00.0000. 0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.6333
MPEG Audio Decoder (MAD),0x00600000,1,1,MpaDecFilter.ax,1.00.0000.000 0
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Gretech Video Filter,0x00200000,1,1,GVF.ax,2.02.0008.0034
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6333
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.6333
Gretech OGG Source Filter2,0x00200000,0,1,GSFU.ax,1.00.0000.0011
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
Gretech FLV Source Filter,0x00200000,0,1,GSFU.ax,1.00.0000.0011
Gretech MPEG Source Filter2,0x00200000,0,1,GSFU.ax,1.00.0000.0011
Gretech Network(MP4) Filter,0x00200000,0,1,GNF.ax,1.00.0000.0002
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.6333
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Gretech AsfEx Source Filter,0x00200000,0,1,GSFU.ax,1.00.0000.0011
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5 145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc.dll,11.06.0000.505 27
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.6333
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Gretech AVI Source Filter,0x00200000,0,1,GSFU.ax,1.00.0000.0011
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6333
Gretech Network(OGG) Filter,0x00200000,0,1,GNF.ax,1.00.0000.0002
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.6076
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.6169
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.6333
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.6333
ATI MPEG Video Encoder,0x00200000,1,1,atimpenc.dll,11.06.0000.505 27
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.00 01.0001
ATI MPEG Multiplexer,0x00200000,2,1,atimpenc.dll,11.06.0000 .50527
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
Gretech Audio Filter,0x00200000,1,1,GAF.ax,1.00.0000.0010
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000. 4504
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
Gretech Network(FLV) Filter,0x00200000,0,1,GNF.ax,1.00.0000.0002
Gretech OGG Source Filter,0x00200000,0,1,GSFU.ax,1.00.0000.0011
Gretech Network(AVI) Filter,0x00200000,0,1,GNF.ax,1.00.0000.0002
ATI Video Scaler Filter,0x00200000,1,1,atimpenc.dll,11.06.0000.5052 7
DXVA Filter,0x00200000,1,1,Mpeg2DecFilter.ax,1.00.0000. 0000
DirectVobSub,0x00200000,2,1,vsfilter.dll,3.00.0000.0236
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0 001.0001
Gretech MKV Source Filter,0x00200000,0,1,GSFU.ax,1.00.0000.0011
DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,3.00.0000.023 6
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.6169
Gretech Source Filter,0x00200000,0,3,MediaSource.ax,1.03.0010.003 4
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.6169
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.6333
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
DC-Bass Source,0x00400000,0,1,DCBassSourceMod.ax,1.05.0002 .0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600 .6333
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Gretech Network(SHOUTcast) Filter,0x00200000,0,1,GNF.ax,1.00.0000.0002
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.03.4530.0000
LAV Splitter Source,0x00400001,0,1,LAVSplitter.ax,0.60.0001.000 0
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Gretech Network(GOM) Filter,0x00200000,0,1,GNF.ax,1.00.0000.0002
Gretech AAC Source Filter,0x00200000,0,1,GSFU.ax,1.00.0000.0011
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.6 512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.6512
VP7 Decompressor,0x00800000,1,1,vp7dec.ax,7.00.0010.00 00
Gretech MP3 Source Filter,0x00200000,0,1,GSFU.ax,1.00.0000.0011
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.260 0.6076
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.6169
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6 333
Gretech MP4 Source Filter,0x00200000,0,1,GSFU.ax,1.00.0000.0011
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.6333
QQ Source,0x00200000,0,1,,
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.6333
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.6333
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.03.4530.0000
ATI Video Rotation Filter,0x00200000,1,1,atimpenc.dll,11.06.0000.5052 7
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00. 0001.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.6333
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.6333
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.6333
LAV Audio Decoder,0x00800003,1,1,LAVAudio.ax,0.60.0001.0000
LAV Video Decoder,0xff800000,1,1,LAVVideo.ax,0.60.0001.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
DScaler Mpeg2 Video Decoder,0x00800000,1,1,MpegVideo.dll,0.00.0006.000 0
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6 333
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.6333
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.03.4530.0000
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.6333
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Lagarith Lossless Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
x264vfw - H.264/MPEG-4 AVC codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.6333
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6333
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6333
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.6333
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600 .6333
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.6333
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.6333
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.6333
AC-3 ACM Extensible,0x00200000,1,1,quartz.dll,6.05.2600.633 3
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.6333
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.6333
AC-3 ACM Codec,0x00200000,1,1,quartz.dll,6.05.2600.6333
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.6333
Audio Capture Sources:
Creative Sound Blaster PCI,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.6333
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.6333
WDM Streaming Capture Devices:
Creative Sound Blaster PCI,0x00200000,2,2,,5.03.2600.5512
WDM Streaming Rendering Devices:
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.6161
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.6161
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.6161
Audio Renderers:
Creative Sound Blaster PCI,0x00200000,1,0,quartz.dll,6.05.2600.6333
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.6333
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.6333
DirectSound: Creative Sound Blaster PCI,0x00200000,1,0,quartz.dll,6.05.2600.6333
WDM Streaming System Devices:
Creative Sound Blaster PCI,0x00200000,10,2,,5.03.2600.5512
Plz help me assist to play High definition videos smoothly in GOM Player.
*** VIDEO INFO ***
Input Size : 768 x 432
Output Type : YUY2
Output Size : 768 x 432
FrameRate(Frame/sec) : 0.00 (25.00)
*** AUDIO INFO ***
SampleRate(Sample/sec) : 48000
Channels : 2
KBitRate(KBit/sec) : 129
Results 1 to 1 of 1
