  1. hi everyone, just curious if anyone has used, or currently uses Mainconcept TotalCode Studio, and if so, is it very good.
    http://www.mainconcept.com/products/applications/totalcode-studio.html
    cheers
  2. Banned
    Nov 2005
    it's very expensive and in all honesty it's not worth the $1000 or $1500 they ask for it, especially when you can get the same encoding engine in Sorenson for $800, the same engine minus a few options in Sony Movie Studio Premium for $80 or just use legally free open source based apps.
    now, when the day comes that it offers a gpu powered hevc encoder, that answer may change.
  3. hi, thx for the reply, i assume you refer to this platinum version ?
    http://www.sonycreativesoftware.com/moviestudiope
    i am curious to give it a go.
  4. Banned
    Nov 2005
    that's the one.
