Results 1 to 1 of 1
  1. Hello all,
    I'm trying to save a livestream from this website: http://cleverproducciones.com/tv-online.html. The stream will be active from about 4:45pm till 10:00pm EST today.
    I have not been able to capture the RTMP stream using GetFLV, VLC, URL Snooper 2, or RTMPExploreX.
    If I change my User Agent in Chrome to an iPhone, then I can access a different RTMP stream that I can record perfectly in VLC. However, this is a very low quality stream, and it makes the ball difficult to follow much of the time.
    rtsp://mobilestr1.livestream.com/livestreamiphone/cleverentertainmenttv
    Using RTMPExploreX I was also unsuccesful:
    Streaming on rtmp://0.0.0.0:1935
    WARNING: Trying different position for client digest!
    Processing connect
    app: mogulus-edge/cleverentertainmenttv
    flashVer: WIN 12,0,0,77
    swfUrl: http://cdn.livestream.com/chromelessPlayer/v21/playerapi.swf?iconColor=0xcccccc&iconColorOver=0xe7e7e7&mute=false&color=0x000000&allowchat=true&jsEnabled=false&time=&width=640&height=360&autoPlay=false
    tcUrl: rtmp://xcleverentertainmenttvx.e.channel.livestream.com/mogulus-edge/cleverentertainmenttv
    pageUrl: http://cdn.livestream.com/embed/cleverentertainmenttv?layout=4&color=0x000000&autoPlay=false&mute=false&iconColorOver=0xe7e7e7&iconColor=0xcccccc&allowchat=true&height=360&width=640
    ERROR: RTMP_ReadPacket, failed to read RTMP packet header
    Closing connection... done!
    Processing connect
    app: mogulus-stream-edge/cleverentertainmenttv
    tcUrl: rtmp://212-68.livestream.com/mogulus-stream-edge/cleverentertainmenttv
    Playpath: rtmp://212-96.livestream.com/affiliateStream/cleverentertainmenttv/6c69766572657065617465723a72746d703a2f2f3231322d39362e6c69766573747265616d2e636f6d2f6d6f67756c75732f636c65766572656e7465727461696e6d656e7474762f63616e616c636c657665723030303032303134303430372d3137353433342d6d656469756d5f363738
    Saving as: 6c69766572657065617465723a72746d703a2f2f3231322d39362e6c69766573747265616d2e636f6d2f6d6f67756c75732f636c65766572656e7465727461696e6d656e7474762f63616e616c636c657665723030303032303134303430372d3137353433342d6d656469756d5f363738
    INFO: Metadata:
    INFO:   author                canalclever
    INFO:   copyright             Procaster 20.3.0
    INFO:   broadcasting_app      Procaster 20.3.0
    INFO:   operation_system      Windows 7  Service Pack 1 (build 7601), 32-bit
    INFO:   presetname            Custom
    INFO:   creationdate          2014.04.07-17:54:37
    INFO:   audiocodecid          mp4a
    INFO:   audiosamplerate       44100.00
    INFO:   audiochannels         2.00
    INFO:   audiodatarate         128.00
    INFO:   videocodecid          avc1
    INFO:   avcprofile            66.00
    INFO:   avclevel              0.00
    INFO:   width                 768.00
    INFO:   height                432.00
    INFO:   videodatarate         550.00
    INFO:   title                 Procaster stream
    INFO:   videodevice           Procaster Video
    INFO:   framerate             25.00
    INFO:   videokeyframe_frequency2.40
    INFO:   audiodevice           Procaster Audio
    INFO:   audioinputvolume      100.00
    INFO:   streamIdentifier      84D1DA
    INFO:   lsChannelName         cleverentertainmenttv
    WARNING: ignoring too small audio packet: size: 0
    When I tried using RTMP streams found in URLSnooper2 in RTMPDump, all had the same error as above "failed to read RTMP packet header".
    Would anyone be able to help me figure out how to do this?
