Hi-
I posted that I have a TVR140 Sony Digital8 camcorder that I want to capture digital stills and taped video to conver to VCDs for storage.
I have a HP 520n it has TWO usb's on the front of the PC. The camera came with A USB conector and PIXELA software.. I tried to capture video and stills but the quality is HORRIBLE. All blurred?
I do NOT have a capture card? IS there just software to but to use with the USB or should I spring for a capture card with software and firewire?
Spankey
usb capture has the poorest video quality,followed by ieee1394 firewire
and the best quality is with i.link.Read "how to capture"
I don't know the quality of USB-transferred video. But to get the best quality out of a digital camcorder, you'll need a firewire card. This would allow you to 'transfer' (not capture) your video from D8 to your harddrive.
You can also capture the video to your HD, using an analog capture card, by using the analog out of your cam to the input of the capture card. But that defeats the purpose of your cam's firewire port.
Either way, you're going to buy a card. So I would suggest that you buy a firewire card, instead of an analog capture card.
hope this helps. -
ieee1394 is firewire is i.Link etc. etc. etc.... ieee1394 firewire and [...] i.link
Firewire and i.link are just "brand" names for ieee1394
which isn't the same thing as quality electronics.
Allan
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
