how to Unlocking
Model: WDC WD6400BEVT-22A0RT0
Firmware Revision: 01.01A01
Serial Number: WD-WX70AC960088
Buffer size: 8388.6 KB
PHYSICAL PARAMETERS:
LBA mode is supported
LBA-48 mode is supported
Sectors available with LBA commands: 268,435,455
Sectors available with LBA48 commands: 1,250,263,728
Full device capacity: 640,135,028,736 bytes
SECURITY:
Security features is supported
The drive is currently LOCKED
Security level: High
Device needs either USER or MASTER password to be unlocked.
FEATURES:
SMART is supported
HPA (Host-protected area) is supported
AAM (Automatic acoustic management) is supported
Streaming feature set is not supported
QUEUING:
Command Queuing is supported by the device
Maximum Queue Depth: 32
As gonca says, you MUST get the password from whoever you got the drive from. DriveLock is a commercial encryption product. You won't be able to crack the password.
