If anyone could offer some advice it would be most welcomed-
using DVDit PE and its pissing right off- it won't let me use the avi's that i captured in premiere or the MPEG's I created from these with TMPGEnc.
I know, you're thinkin, 'codecs,' right?- Well, both these files will play in Windows Media Player yet they're not accepting it in DVDit. Doesn't this peice of shit software come with codecs?? and if not why are the codecs that are playing these files for WMP not playing them in DVDit??
i am experiencing rapid hair loss
......help, anyone...
Results 1 to 14 of 14
I use DVDit PE with mpegs created in Tmpgenc, if you supply a few more details on your problem, procedure followed, Tmpgenc settings NTSC/Pal, error messages received etc I may be able to help.
I get a message saying that the AVI and mpeg files are unsupported but in the manual it says, and i quote, any media that plays in Windows Media Player is supported by DVDit. I used TMPGEnc to endcode the Mpegs and the DV AVI's are straight outta the camera, they haven't been edited in premiere or anything. The avi's won't preview in file properties, mind you, something about a DVSD codec, but they play in WinMediaPlayer.
Something else as well if anyone can figure out this one. If i edit the dv files in premiere and then export as DV AVI they won't function in TMPGEnc- any idea's there either?? -
not very familiar with using DV source material but seem to remember reading on another thread that intsalling a DV codec other than the MS one solves a lot of problems with compatibility issues, might be worth searching the forum for more info. Sorry I cant say more.
I had some of the same problems with DVDit pe 2.5.2 and finally got fed up and downloaded the free ULEAD DVD Movie Factory and it accepted the avi's immediately and I procuded a dvd in no time with no error messages during the process. Try doing that with DVDit. Oh and the trial is fully functional for 30 days and is only 45.00 if you buy it. Maybe try Ulead to convert avi to mpeg and then try importing to DVDit, or use ULEAD to make your dvd. Just a thought.
DVDit is very disappointing to me, it looks like a million bucks but functions like a piece of junk. So much potential yet so many errors, what a shame. -
I tried downloading another DV codec- the mainactor DVSD codec- this hasn't made any difference to the DVDit acceptance policy. In the windows properties dialog the preview still states it hasn't found a DVSD codec!?!?!
I tried a quicktime mov file as well and DVDit says it hasn't got the codec installed for that either. Is DVDit just a useless peice of shit or is DVDit a useless peice of shit..... -
I just re-read your posts and if I understand you correctly you are trying to import .avi file straight into DVDit. If this is the case then I have one piece of advice for you. DONT! The built in Mpeg encoder is very poor and very slow. Covert your .avi files to mpeg2 using TmpGenc or your favouritre encoder. I use the supplied templates for Pal and slightly modified ones for NTSC source material. It took me a while to persuade DVDit PE 2.5 to accept my Mpegs but I now have it figured out. E-mail me for further details
right, lets get this straight-its the MPEG decoder its having problems with.
It isn't detecting it. Is this because the decoder is embedded in Media Player or something and i have to install a decoder in the system cos when i go to multimedia properties (win98) i do not see a mpeg decoder.
Does this help make my troubles any clearer?? -
Hi,
first of all i've been in your postion for the last few months, but now i'm racking them productions out on DVD-R
Quote.
My TMPGenc file i created will play in windows media player, but when i try to import it into dvdit! it says it can't find a suitable decoder. Plz help, i am experiencing rapid hair loss.
For DVD-it to find a suitable decoder you have to do the following :-
If it is M2v, Rename your m2v to mpv. If its not skip this bit and go do the following:-
Start to play your mpeg file in windows media player, then pause it DO NOT STOP VIDEO
Then minimize media player and open dvdit, import file in media section, then "voila" your mpeg will load in DVDit
Let me know if this sorts your problem.
Rimmer"Smoke Me A Kipper, I'll Be Back For Breakfast!! :D -
fan-fukin-tastic, that done the job,
cheers rimmer old boy!!
i'm even going to enable the smilies for that..
Strange process to enable this...
Why such temporamental behaviour I wonder?? -
Any more sugg's, cause i've got the same prob. i was woundering if it could be because i,m using the new tmpgenc? files i did with the old encoder have no prob... but i also used vbr instead of cq... i tried doing as RimmeR...
I'm getting a message saying it can't find a suitable decoder... could it be a problem linked to mmc7.6?(i don't think so but...) -
Tried to answer your e-mail Steeviehoopa but it bounced with unkown user. You seem to have found your answer anyway
By the way i tried with an older version of tmpgenc it seems to work... it seems it's a slight bug with the new version
AVCHD \ Premiere \ Codec \ Smooth Troubles
By lifemaster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Jun 2010, 02:51 -
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 13:51 -
Black and White Insanity
By craigarta in forum Video ConversionReplies: 4Last Post: 12th Nov 2009, 09:22 -
TV Out Troubles.
By SE14man in forum Newbie / General discussionsReplies: 54Last Post: 11th Oct 2007, 16:55 -
TmpgEnc + mkv (renamed to .avi) + .ass + ffdshow - DirectVobSub = Insanity
By Sumgai in forum SubtitleReplies: 3Last Post: 20th Jun 2007, 23:21
