Results 31 to 40 of 40
You could look at specialty retailers like 220-electronics or world-import. They have comprehensive descriptions for the models they sell.
http://www.220-electronics.com/blu-ray-dvd/region-free-dvd-player/pioneer-hdmi-1080p-r...vd-player.html
http://www.world-import.com/pioneer-dv-2012-k-region-free-dvd-player.htm -
OK, you're right, those was HDMI Audio settings.
In the HDMI Video settings I have the following choices:
1920x1080p
1920x1080i
1280x720p
720x480p
720x480i
I tried the second one already, 1920x10801, but the Bravia still wouldn't play the video (I still get a message "Unsuported signal. Check output device" -
BTW, why has the price of my Pioneer Dv610av-s, gone from about $100 when I bought it a year and a half ago, to $1,000 now?...... http://www.amazon.com/gp/offer-listing/B001PBQNPO/ref=dp_olp_new?ie=UTF8&condition=new
My current DVD player, the Pioneer DV-610AV-s, already is a "multi-region" player. I can see that it is playing the PAL disc as the digital timer advances and I can hear the audio through my SONY Bravia.
The problem seems to be that SONY Bravias do not support a PAL video signal. Are you saying there's a way within a multi-region player to convert the output signal from PAL to NTSC?
Or do just certain multi-region players (known as "converters") do this? -
Some multi-region players do not convert and can only play video using its original system. Other players always convert to whatever video system the player is set to use at the factory. (I have a Philips DVD player and an LG Blu-Ray player which both convert from PAL to NTSC automatically. Neither is multi-region BTW.) I have heard that a few players allow users to choose the TV system to use for output.
I've found in the manual, page 52, there is a way to force a video system (NTSC in your case):
"Setting the TV system
The default setting of this player is AUTO, and unless you notice that the picture is distorted when playing some discs, you should leave it set to AUTO. If you experience picture distortion with some discs, set the TV system to match your country or region’s system. Doing this, however, may restrict the kinds of disc you can watch. The table below shows what kinds of disc are compatible with each setting (AUTO, NTSC and PAL ).
1 If the player is on, press STANDBY/ ON to switch it to standby.
2 Using the front panel controls, hold down >>| then press STANDBY/ON to switch the TV system.
The TV system changes as follows:
• AUTO -> NTSC
• NTSC -> PAL
• PAL -> AUTO"
Could you try that? -
I'm curious - what does this say about you since the answer, again what several of us told you over and over and over here, was in the manual all the time? To be honest with you, since you're clearly too lazy to do even the slightest amount of work, your last question there does not deserve an answer.
Many thanks to all of you who took the time to be so helpful and friendly.....you guys are the best!!
DVD "no signal" with component connection
By medic in forum Authoring (DVD)Replies: 9Last Post: 14th Sep 2015, 17:20 -
"No Signal Input" - Avermedia Live Gamer Portable
By avermediauser in forum Capturing and VCRReplies: 3Last Post: 7th Jul 2015, 15:56 -
SONY BRAVIA - 32" LED - Video play back issues from USB port.
By iRecycle in forum DVB / IPTVReplies: 13Last Post: 10th Aug 2013, 02:15 -
VGA to DVI adapter only sending "sleep" signal.
By saboran in forum ComputerReplies: 2Last Post: 10th Feb 2013, 06:36 -
Sony Bravia 40" BX400 - USB Video Format issue
By dreamcast in forum Video ConversionReplies: 4Last Post: 16th Oct 2010, 08:49
