Hi, I have made some backups of my DVD's to svcd using DVD2svcd. I just did Dracula2000 and it made 2 cd's. The problem I am having is that CD2 is over the 800 minute limit. CD1 is fine but cd2 wont fit on a disk. I have the settings for the # of disks set to default. Can someone tell me what may be the problem? Thank you.
In the Bitrate section, change the CD size to 740 and do it again. I hope it helps.
Rgds
Stelios
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
