Command
Errorffmpeg -i "http://hls.spuul.com/va/movies/10810007-f45c572c/s_jw.m3u8?Policy=eyJTdGF0ZW1lbnQiOlt7IlJlc291cmNlI joiKi92YS9tb3ZpZXMvMTA4MTAwMDctZjQ1YzU3MmMvc19qdy5 tM3U4IiwiQ29uZGl0aW9uIjp7IkRhdGVMZXNzVGhhbiI6eyJBV 1M6RXBvY2hUaW1lIjoxMzk2NjA0Njg4fSwiSXBBZGRyZXNzIjp 7IkFXUzpTb3VyY2VJcCI6IjAuMC4wLjAvMCJ9fX1dfQ__&Sign ature=q0mDnbxjW8BL2RJ55IZRV9EOpXx1FaOFoaKnaQ8mBrvP 202Xgl8CByPiGtqGOJkL1Ym81xQ8cfh4hxFtWijhYJ-AV74KqZucBeoWen8S5SbIK4xw03PSHCE-93ceicvak6c8GzDuyQ0MFJYA0aUW3x3tKG4P~gM7XW3sRRJUfT Y_&Key-Pair-Id=APKAJMKGGGYZCUBNLANQ" -c copy dump.ts
I get a key file linked below, but the content is unreadable in both ASCI and UTF.Code:D:\Users\root>ffmpeg -i "http://hls.spuul.com/va/movies/10810007-f45c572c/s_j w.m3u8?Policy=eyJTdGF0ZW1lbnQiOlt7IlJlc291cmNlIjoiKi92YS9tb3ZpZXMvMTA4MTAwMDctZj Q1YzU3MmMvc19qdy5tM3U4IiwiQ29uZGl0aW9uIjp7IkRhdGVMZXNzVGhhbiI6eyJBV1M6RXBvY2hUaW 1lIjoxMzk2NjA0Njg4fSwiSXBBZGRyZXNzIjp7IkFXUzpTb3VyY2VJcCI6IjAuMC4wLjAvMCJ9fX1dfQ __&Signature=q0mDnbxjW8BL2RJ55IZRV9EOpXx1FaOFoaKnaQ8mBrvP202Xgl8CByPiGtqGOJkL1Ym 81xQ8cfh4hxFtWijhYJ-AV74KqZucBeoWen8S5SbIK4xw03PSHCE-93ceicvak6c8GzDuyQ0MFJYA0aU W3x3tKG4P~gM7XW3sRRJUfTY_&Key-Pair-Id=APKAJMKGGGYZCUBNLANQ" -c copy dump.ts ffmpeg version N-62121-g634636e Copyright (c) 2000-2014 the FFmpeg developers built on Apr 3 2014 23:37:34 with gcc 4.8.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp eex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aa cenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavp ack --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable -zlib libavutil 52. 73.100 / 52. 73.100 libavcodec 55. 56.107 / 55. 56.107 libavformat 55. 36.101 / 55. 36.101 libavdevice 55. 11.100 / 55. 11.100 libavfilter 4. 3.100 / 4. 3.100 libswscale 2. 6.100 / 2. 6.100 libswresample 0. 18.100 / 0. 18.100 libpostproc 52. 3.100 / 52. 3.100 [http @ 00000000045ef900] HTTP error 403 Forbidden http://hls.spuul.com/va/movies/10810007-f45c572c/s_jw.m3u8?Policy=eyJTdGF0ZW1lbn QiOlt7IlJlc291cmNlIjoiKi92YS9tb3ZpZXMvMTA4MTAwMDctZjQ1YzU3MmMvc19qdy5tM3U4IiwiQ2 9uZGl0aW9uIjp7IkRhdGVMZXNzVGhhbiI6eyJBV1M6RXBvY2hUaW1lIjoxMzk2NjA0Njg4fSwiSXBBZG RyZXNzIjp7IkFXUzpTb3VyY2VJcCI6IjAuMC4wLjAvMCJ9fX1dfQ__&Signature=q0mDnbxjW8BL2RJ 55IZRV9EOpXx1FaOFoaKnaQ8mBrvP202Xgl8CByPiGtqGOJkL1Ym81xQ8cfh4hxFtWijhYJ-AV74KqZu cBeoWen8S5SbIK4xw03PSHCE-93ceicvak6c8GzDuyQ0MFJYA0aUW3x3tKG4P~gM7XW3sRRJUfTY_&Ke y-Pair-Id=APKAJMKGGGYZCUBNLANQ: Input/output error
Download: http://www.sendspace.com/file/xnoewe
This works, but how do you get the renditions.m3u8 link? Is it received right before the parts start downloading or when the video player loads?Code:
ffmpeg -i "http://hls.spuul.com/va/movies/10810007-f45c572c/0010/renditions.m3u8?Policy=eyJTdGF0ZW1lbnQiOlt7IlJlc291cmNlIjoiKi92YS9tb3ZpZXMvMTA4MTAwMDctZjQ1YzU3MmMvc19qdy5tM3U4IiwiQ29uZGl0aW9uIjp7IkRhdGVMZXNzVGhhbiI6eyJBV1M6RXBvY2hUaW1lIjoxMzk2NjA0Njg4fSwiSXBBZGRyZXNzIjp7IkFXUzpTb3VyY2VJcCI6IjAuMC4wLjAvMCJ9fX1dfQ__&Signature=q0mDnbxjW8BL2RJ55IZRV9EOpXx1FaOFoaKnaQ8mBrvP202Xgl8CByPiGtqGOJkL1Ym81xQ8cfh4hxFtWijhYJ-AV74KqZucBeoWen8S5SbIK4xw03PSHCE-93ceicvak6c8GzDuyQ0MFJYA0aUW3x3tKG4P~gM7XW3sRRJUfTY_&Key-Pair-Id=APKAJMKGGGYZCUBNLANQ" -c copy dump.ts
Hi I am trying to download the video but getting 403 error any help will be appreciated
http://hls.spuul.com/va/tvshows/11021013030-4741b41e/0011/renditions.m3u8
This is the link which I am trying to get through FFMPEG
how to play Http or M3u8 stream with a webplayer
By Biggy in forum Video Streaming DownloadingReplies: 2Last Post: 3rd Apr 2014, 03:43 -
Help streaming /dev/video0 over http using VLC or ffserver/ffmpeg
By limiteddi in forum Video Streaming DownloadingReplies: 0Last Post: 26th Dec 2013, 21:22 -
403 Forbidden
By BLSAMPLES in forum ComputerReplies: 11Last Post: 3rd Apr 2013, 06:05 -
Video streaming over http with vlc and ffmpeg
By lusky in forum Video Streaming DownloadingReplies: 4Last Post: 7th Apr 2010, 04:54 -
ffmpeg.exe has stopped working error when trying to add asset
By skeet09 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 27th Oct 2009, 15:15
