I'm an old fashion editor. What I'm use to is when I get row material a first divide it into bins, relevant to the content of the shots. Then I find it much easier to put it together by picking up from different bins whatever I need.
I can not find the way to do it with video pad. I tried to import row material and put it on the timeline. I cut it, but when I want to save it to appropriate bins - IT DOESN"T WANT to go anywhere.
Please advise
Maks
What is video pad?
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
A quick perusal of their website and YouTube site shows no obvious way to make subclips. It may not be possible.
You may want to consider a more capable NLE like Vegas Movie Studio. What did you use before? -
https://www.videohelp.com/tools/VideoPad-Video-Editor
I gave it a try some years ago, and I can only say its installer sucked too much ¬¬ ,
PERHAPS they have improved the application a lot since then
Yes, you could be wrong.
Vegas Movie Studio can usually be found for around $40. Current version is 13 and there's a free trial. (Vegas 7 MAY work depending on your source footage and OS.) I'm not a shill, but I feel like it sometimes.
Should deinterlace VHS captured material ?
By macmithos in forum MacReplies: 17Last Post: 5th Jan 2016, 10:56 -
Problem with 3D material question
By Seeker47 in forum Video ConversionReplies: 13Last Post: 15th Feb 2014, 16:03 -
Seperating MKV 3D files
By Mike001 in forum EditingReplies: 1Last Post: 15th Oct 2011, 01:28 -
Problems with capturing VHS material
By Philiboy in forum Capturing and VCRReplies: 5Last Post: 7th Jan 2011, 21:35 -
Edit out material from dvd's/Need advice please
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 27th Oct 2010, 18:15
