I am trying to edit out credits out of some stuff from the source files of rips that I did & its not doing it perfectly. Is there a reliable tool out there for this ? I am trying MPEG-VCR but I have no idea on what option to save for "LOSSLESS" editing. I just want to input video & cut what I dont want & export & not lose any quality
If your VOB files are part of a DVD you can remove the credits using VobBlanker. But only on GOP boundaries (roughly every half second). There's a guide to doing it here:
http://download.videohelp.com/jsoto/guides/VobBlanker/prevcut/index.php
If the credits are their own cell, it may be as easy as blanking the cell.
Otherwise something like MPEG2CUT2 can remove credits from MPGs and VOBs, again on GOP boundaries, and it'll save it as an MPG (but without reencoding). You said you were having trouble doing it 'perfectly', so maybe you need to do it from specific frames. That gets a little more tricky.
Title Credits/End credits ... Character by Character
By tsk1979 in forum Newbie / General discussionsReplies: 9Last Post: 14th Nov 2013, 00:31 -
Editing Opening and Ending Credits in an MKV
By TheLaserdisc in forum EditingReplies: 3Last Post: 8th Jul 2011, 02:55 -
editing mpg
By chicagomama in forum EditingReplies: 5Last Post: 19th Oct 2010, 20:50 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
VOB editing
By ek020 in forum EditingReplies: 7Last Post: 23rd Apr 2009, 16:20
