There's another x265 project out there, see: https://github.com/lheric/x265
(Kurtnoise posted a link to a compiled version over at: https://forum.doom9.org/showthread.php?t=170395)
Did anybody test it?
Cu Selur
Warning: The site's security certificate is not trusted!
I tried but I couldn't get it to work and no-one could post a working command. -
yes, doom9 forum has a self-signed certificate,.. (better then none I guess)
so this is written in plain C, huh? this would be perfect for porting to either CUDA or Open CL.
edit: i think this is the "real" x265, the original one that the chinese programmer started using x264 as a base, before the MCW guys took over the project. i guess he kept developing the version he started.
either way, an x265 encoder written in pure C should be very easy to run on a gpu with little modification. -
might be, not sure...i think this is the "real" x265, the original one that the chinese programmer started using x264 as a base,
the author named at lheric/x265 is 廖梓鑫 (= Liào Zǐ Xīn) which isn't mentioned at http://code.google.com/p/x265/
x265 vs x264
By deadrats in forum Video ConversionReplies: 71Last Post: 10th Jan 2016, 06:14 -
Problem with x265
By protoX in forum Video ConversionReplies: 9Last Post: 25th Jan 2014, 14:15 -
[S.E.0.] x265 sucks ;-P
By El Heggunte in forum TestReplies: 8Last Post: 21st Jan 2014, 00:14 -
Help with x265
By mianghuei in forum Video ConversionReplies: 0Last Post: 12th Dec 2013, 04:36 -
Divx or x265?
By Mephesto in forum Video ConversionReplies: 3Last Post: 30th Oct 2013, 10:01
