I have a couple SVCD movies in BIN/CUE format which I can't do anything with....all of them have the same problem. I think it's because they have chapters.
Each SVCD contains about 6 to 10 MPEG files (according to VCDGear). I tried ripping out the MPEG files using VCDGear, but when it's done, the MPEG files will not play in Windows Media Player.
Does VCDGear support extracting of SVCD MPEGs ??
If so, what should the settings be ??
What should the setting be if the SVCD has chapters ??
I tried burning the BIN/CUE files with Fireburner, but I always get a WRITE ERROR about 1/4 of the way through.
Wasn't there some kind of trick (something about editing the CUE file in some way) that would make it possible to burn these SVCD "chaptered" BIN/CUE files?
I would really appreciate any help....
Thanks,
~Urbs~
Hey Urbs,
VCDgear is really for mpeg1 (VCDs). As for the bin/cue... use CDmage or isobuster to see/extract the content of the bin file.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
