Results 1 to 19 of 19
  1. So, i bought my elgato gamin capture hd like.. 3 days ago and everything worked.. I can see my xbox 360 on the elgato software and so on but when i stop recording a gameplay i save the video and what i can see is a black screen.. and if i try to edit it on sony vegas or other programs i can see a Green Screen so please help me :'(
  2. Upload a short sample so we can see if the recording is ok.
  3. I'm not good with english btw you mean you want me to upload a short video on youtube? But you can only see a black screen.. I can screenshot my elgato settings
  4. Originally Posted by Erbula View Post
    No, not to Youtube. Upload a short sample to this web site. There is an "Upload files/Manage attachments" button below most of the edit boxes when you post a message. A 5 or 10 second sample is enough.
    YOU can only see a black screen. We don't know if the recording is bad or something about your computer that prevents you from seeing the picture in the recording. Bad TS reader/splitters and codecs often display that symptom.
    Or try playing one of your videos with VLC. It doesn't rely on system installed components.
  5. Alright its stuck on Uploading File(s) - Please Wait .. Well btw idk i dragged my video on this page and my video opened on the browser and i could see its weird.. now i'm downloading VLC
  6. AND YEPPP I can see my videos with VLC.. SO what's the problem with my pc?
  7. So the files are OK. What player were you trying to play them with before VLC?
  8. Are you there buddy?
  9. DECEASED
    Jun 2009
    Heaven
    "Windows7 Preferred Filter Tweaker" should make your WMP start acting decently.
    I don't use Sony Vegas, so I cannot help you with that.
  10. WMP uses DirectShow filters to open TS, MP4, etc. files. It also uses DirectShow h.264 decoders, audio decoders, etc. You need to figure out which component is causing your black screen problem. Unfortunately, unlike many other players, WMP doesn't offer any diagnostics that will let you track this down. The h.264 decoder seems like the most likely. Try installing a different h.264 decoder. I like to use ffdshow because it includes decoders for almost all common audio and video codecs and they can be easily enabled or disabled. If another h.264 decoder doesn't help you can try a different reader/splitter -- LAV or Haali.
  11. Installed both still have black screen :'(
  12. It can be hard to get windows to use the right codecs and filters. Did you try the Preferred Filter Tweaker suggested by El Heggunte?
  13. Yep but i dont know what to check.. Can you help me with TeamViewer 9?
  14. Really, i can see my videos with all other players but with WMP I can't..
  15. DECEASED
    Jun 2009
    Heaven
    Now we see that your current problem has nothing to do with the original title of this topic
    ("Help me with elgato gaming capture hd").
    IMHO, now you should focus on being able to edit those captured videos
    Sony Vegas surely is not the only tool in the kit, and probably you should spend some more time doing a lot of reading.
    Also, probably you'd better start a brand-new topic in the Editing forum
  16. Unlike WMP, most other players don't rely on DirectShow in their default configurations. Go to Start -> All Programs -> ffdshow -> Video Decoder Configuration. In the left pane select Tray, Dialogs & Paths. In the right pane, on the Tray Icons line, select Modern or Classic. In the left pane select Codecs. In the right pane make sure H.264/AVC is set to Libavcodec. Press OK.
    Now play a video with WMP. Does the ffdshow icon show up in the System Tray? Are you running 64 bit Windows or 32 bit Windows?
  17. Mmm it says that its missing but when i installed ffdshow idk why it said The Driver or UNC share you selected does not exist or is not accesible. Please select another. And for making it work i unchecked something that i dont remember..
  18. Guys, if i reset my pc.. Will it maybe be fixed?
