Results 1 to 9 of 9
  1. Member DarrylReid's Avatar
    May 2011
    Queensland Australia
    I know this may sound like a question but here goes:
    I wish to put several smallish mpeg files onto a flash drive and create a selection menu.
    Is this possible please? I can do it by creating an image file but that does not seem to want to play the game.
    Thanks.
    Yes, it sounds like a question.
    The only method I know of is to make a dvd or blu-ray if you want a menu.
    How are you going to play this? From computers only? Media players?
  3. You can probably do it with a batch file and AUTORUN.INF.
  4. Member DarrylReid's Avatar
    May 2011
    Thanks Baldrick, that's what I suspected.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    does anyone allow usb sticks to autorun? about the worst possible security nightmare imaginable.
  6. Originally Posted by aedipuss View Post
    No one in their right mind.
  7. Member DarrylReid's Avatar
    May 2011
    Thank you for the comments, I had no intention to have the stick auto run.
  8. Create a DVD ISO with your videos and a menu. Put the ISO and VLC (portable) on the drive and use VLC to play the ISO (any portable player that supports ISO images will work). Since you don't want to use AUTORUN.INF you'll have to start it manually.
  9. Member DarrylReid's Avatar
    May 2011
    Fantastic, Thank you, I'll certainly try your suggestion.
