Results 1 to 13 of 13
  1. I have mkv files that i wish to make a dvd out of but every program that i find inserts a watermark when or wont work. Any advice on what program to use.
    Tried AVStoDVD?
    There aren't that many other good free mkv to dvd converters.
  3. I tried to use SUPER and it changed my mkv to dvd format including the two folders for audio and video but im having trouble putting those onto a dvd.
  4. ok i will try that thank you
  5. OK so i did use imgburn but it will not play in a dvd player. it sais wrong disc any ideas, i followed all the instructions in your link
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Can you play the burned dvd with a software player like vlc, mpchc?
    Did you make a ntsc or pal dvd?
    Does your dvd player support dvdr/w media?
  7. yes it plays in vlc
    the player said pal disc.. i dont know if i did something wrong
    yes it does
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    And your player supports PAL? Or else must you probably make an NTSC.
  9. the player does not but how do i set that in the imgburn
  10. I'm a Super Moderator johns0's Avatar
    canada
    You will have to change the mkv from pal to ntsc if you are using a ntsc player,best way to do that is use a dvd authoring program that will let you set it to ntsc.
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    Yep. You must do that in the converting process(in super).
