Hi
How can I get rid of the 30 day trial period? I could not find any lisence fee to pay at their site. Is there a crack to this and where?
Regards
Stelios
Dude,
This is not the place for that sort of question....remember, your on the world wide web....it you look hard enough, you will find it. -
Buy TMPGEnc Plus:
http://www.pegasys-inc.com/e_buyinfo.html
Do not ask for cracks
Hi Truman
Thanks for the link. I only asked for a crack because I was not able to buy the plus version. Does this plus version though works with DVD2SVCD program? What is the difference of the plus version?
Thenks
Stelios -
The differences of the TMPG versions are listed here:
http://www.pegasys-inc.com/e_release02.html
I do not work with DVD2SVCD, but according to the latest DVD2SVCD readme "All versions of TMPGEnc should now be supported".
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
