Can somebody tell me why when I have ripped a film using smart ripper / DVD2AVI / TMPGenc the sound seems to jump / go very slow when the picture is dark. Like when at the end of a film, just before the credit's come up and there is a black screen, the film seems to jump and stutter.
It has started doing this on all my recent rip's and ut is doing my head in, am I doing something wrong, or is there a setting I should be changing.
what are the specs of your machine your using and what version of temgenc?
Mikey :lol: -
AMD 1Ghtz /128mb It's funny you should ask what version of TMPGenc I'm using as I have just upgraded to V 2.53.35.130 you know the one that gives you the Project Wizard when you start up.
I never had any probelms with my old version, but when I had to format drive I just downloaded the latest one from their site. -
i sure do know the one that you mean ive upgraded to that also. i thought that it was my machine which was casuing the problem. this is intresting that your having the same prob with the same version. ive got a P4 1.5ghz i think that i might try to go back to the old version and check that out. ill let you know how i get on.
Mikey :lol: -
Thanks, will be keen to know how you get on. If it works ok please can you tell me where you downloaded the old version from and I will give it a go.
Anyone else had the same prob's with the new TMPGenc?? -
m_lea1...
I have just downloaded an older version of TMPGEnc V. 2.02.31.119 and it works great now, no more jumping on the sound and even put the new templates in there to.
thats cool no more jumping then but does this older version still have all te features of the new version?
Mikey :lol:
help jumping from SD to HD
By blacktooth in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 4th Feb 2012, 01:46 -
jumping video
By natty in forum Newbie / General discussionsReplies: 8Last Post: 2nd May 2011, 11:27 -
Jumping over movie
By gbabione in forum DVD RippingReplies: 3Last Post: 11th Apr 2010, 04:54 -
rolling/jumping with VHSc
By highaim in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2009, 21:03 -
Jumping, Stuttering Video
By Smack2k in forum Video Streaming DownloadingReplies: 7Last Post: 6th Jul 2009, 19:36
