I've recorded few programmes on my TV to my external HDD and they are in .TS file format and I checked the video format and it uses MPEG, is there a software which I can cut scenes and join video files together?
Closed Thread
Videoredo or tmpgenc mpeg smart renderer.
You can also cut/join with free software like mpg2cut2, avidemux, free video dub, video to video converter but they aren't as easy and good as the above editors.
First, can you play the files on your computer using Windows Media Player or MPC-HC or VLC? If they're encrypted you will not be able to defeat that and use them.
Otherwise try something like MPeg2Cut2 for free, VIdeoRedo or TMPGenc Smart Renderer paid.
edit: Beaten to it by the master.
I guess it means that the format is not fully supported.
. But you can always try and see how it works. Or else keep trying free video editors.
And after you have seen that all crashes, doesn't cut exactly, etc then try/buy tmpgenc smart renderer.
Edit MPEG-2 Transport Stream
By JonnyAlpha in forum EditingReplies: 4Last Post: 3rd Nov 2013, 18:20 -
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 14:55 -
Try to edit my mpeg but no sound!
By leegundo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 2nd Aug 2010, 10:56 -
How to Edit MPEG with VDubMod and save as MPEG?
By DVFun in forum EditingReplies: 11Last Post: 3rd Nov 2009, 14:32 -
Some help needed, Trying to find the best approach to edit MPEG
By chadwill in forum EditingReplies: 14Last Post: 21st Aug 2009, 06:45
