Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 10 of 10
  1. Hi, Can anybody advise me what I would need in order to download and save the video file from here. not sure if its streamed or embedded
    http://www.zbrushworkshops.com/lessons/how-to-design-appealing-characters-part-2
  2. Member bat999's Avatar
    Feb 2008
  3. The string after "mp4?" is time limited. Load this page;
    http://video.zbrushworkshops.com/players/2kYEXev0-DANIVhJE.js
    Search the page for "2kYEXev0-372918.mp4" and you will get the http link to the video with a current "mp4?" code. Copy the full link within the quotation marks.
  4. Thanks, I'll check it out
  5. Thanks Blimey. That seemed to work. how exactly to you find the info? I have a few more videos but I cant seem to find the correct info I need.
    I'm i doing something wrong here?
    trying to find the link for this video
    http://www.zbrushworkshops.com/lessons/how-to-design-appealing-characters-part-3
    I view the page source
    Found this link http://video.zbrushworkshops.com/players/2cdLBmJk-3ixMjW9w.js
    BUt then I cant find the link to the video
  6. Originally Posted by A3Y55 View Post
    h..p://www.zbrushworkshops.com/lessons/how-to-design-appealing-characters-part-3
    Found this link h..p://video.zbrushworkshops.com/players/2cdLBmJk-3ixMjW9w.js
    keep "DANIVhJE.js"
    for example, for link you find;
    use "2cdLBmJk-" with "DANIVhJE.js";
    http://video.zbrushworkshops.com/players/2cdLBmJk-DANIVhJE.js
  7. Thanks Blimey, That seems to have done the trick!!
    One last thing. I'm also trying to download some clips from here. http://www.runsmartonline.com (You might have to take up the 10 days free to gain access to the clips).
    I cant even access the source code for any of the pages under this domain. Any ideas as to how I might gain access to the clips here?
  8. Originally Posted by A3Y55 View Post
    if you're using Firefox use shortcut CTRL + U and search for mp4
    example
    https://www.runsmartonline.com/secure/flexibility/videos/active-core/stretch_-_active_core.mp4
  9. Thanks for the pointer, work ok for your above like but why does the same principle not apply to the clip on this page? https://www.runsmartonline.com/secure/workouts/base-six/day-1.php
  10. My mistake missed something out. All working now Thanks for the tip!!
