Hi!
Is there a way to store Pan&Scan-preset for this player?
I need 6 nudges in Pan&Scan for the projector to fit my screen (number 1 nudge)
It seems like the ini only can remember 'Video Frame'?
Thanks for help
	I've never used it myself but there's an option to remember the last used pan and scan setting under View/Options/Player.
	In fact, it does not work for me. Can you se a line that tells a Pan&Scan value?
	Woho I found it on another computer with a newer version of MPC-HomeCinema. (1.6.1.4235) Last edited by Mike_B; 17th Mar 2014 at 14:46.
  DVD with just *.ini file in it.By NWSHashBrown in forum DVD RippingReplies: 2Last Post: 23rd Dec 2013, 01:22
  Can't play one mp4 file at KMP and Media Player Classic - Home Cinema x64..By Balema in forum Software PlayingReplies: 5Last Post: 10th Mar 2012, 20:31
  ini file conversion to mp4By pacific77 in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2010, 15:02
  FFDShow with MPC Home Cinema.. How?By ZenMystic in forum Software PlayingReplies: 6Last Post: 10th Jan 2010, 22:17
  BOOT.INI fileBy CSULB71 in forum ComputerReplies: 11Last Post: 26th Dec 2009, 12:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
