So basically if I make a cut with MPG2CUT2 I stand to lose up to 12-15 frames because that is the GOP length and MPG2CUT2 only cuts on GOP boundaries and doesn't reencode anything, whereas if I use something like VideoRedo it can make the cut between frames and then reencodes the 12-15 frames within that GOP?
I just want to make sure I have that straight.
Results 31 to 37 of 37
I must be missing something in the replies, but my question is essentially this:
Let's say I have a 60 minute MPGE2 file. I demux it into a 60 minute M2V video file and a 60 minute AC3 audio file. I then use cutterman to chop the last minute off of the M2V file. Are you saying cutterman will automatically make the same adjustment to the AC3 audio file so that I will now have a 59 minute M2V file and a 59 minute AC3 file that can be remuxed and will still be in sync? If the same cut isn't made to the AC3 file as was made to the M2V file, then the video and audio won't line up anymore when they are remuxed. I would have to cut the AC3 file manually before remuxing it. -
Lose or gain. It depends on what side of the target frame you cut on, and where the target frame is in relationship to the GOP boundaries
Let me clarify with an example
By "gain" I mean lets say you want to cut right beetween frames 8 to 9, keeping frames 0-8 for 9 frames total. But that's right in the middle of a GOP. Instead it will skip to the nearest GOP boundary, right before the next keyframe. So you're left with frames 0-14 for 15 frames instead of a 9 frame clip.
So you lose or gain. You might have extra frames, or too few frames compared to if you used a frame accurate cut. ie. the cuts won't necessarily be where you want them to be. You might some frames from the previous scene, or that scene might be cut short
For mpg2cut2 - If you navigate by keyframes, you can ensure the cut is on keyframe boundaries. Mouse over the buttons in the GUI, and a short description will pop up it's the "<" ">" buttons in the GUI. "Step forward or back 1 GOP" -
Well, I already wasn't impressed with the "professionalism" of the production company used, when they put filler in between (some) segments, but GEEZ! anybody who has been doing this for any time at all should know not to provide a CUT version of the audio stream.
I've done the same "transfer/capture->encode->split for shipping on smaller media" process for years, and it is SIMPLE to output frame accurate encodes to specific time/space boundaries and make the joining be a breeze - even with long-GOP material. And Audio is so small, it is inconsequential to give a complete, uncut copy instead of or in addition to cut versions.
IIWY, I'd not waste MY time on this and take it back to the production company and tell them to do it right or refund your money (or both).
<edit>And if they don't understand, or need assistance with getting it done right, they should own up to it. And talk to me, if need be.</edit> -
Let's see, they added a few seconds of blank blue screen at the end of the first DVD, right after they cut the video. I'm not sure why they did that. They required more than 1 DVD based on the length of the VHS tape I sent them, so they had to split it across 2 DVDs, which means they had to split the video somewhere. I suppose they could have put the entire thing on one dual layer DVD. You are correct they did not provide me with an uncut version of the audio.
Maybe videoredo will be able to cut out the few seconds of blank blue filler screen and seamlessly join the 2 video segments together. I haven't tried it yet.
I just emailed the service I used to see if they can redo it using a dual layer DVD, which would allow the entire uncut video to fit on one disc.
Testing H264/AVC frame accurate editing (AVCHD/MOV/MP4/MKV)) of SolveigMM
By DmitryV in forum EditingReplies: 17Last Post: 20th Oct 2023, 05:47 -
Cut MKV frame accurate
By Dimuk in forum Newbie / General discussionsReplies: 23Last Post: 29th Apr 2022, 09:20 -
Help: MP4, frame-accurate editing, lossless/smart encoding, fast navigation
By BobP2013 in forum EditingReplies: 6Last Post: 28th Jul 2013, 12:18 -
Frame accurate WMV edits
By jbeezer in forum EditingReplies: 5Last Post: 5th Jul 2010, 14:41 -
ISO: frame accurate *multiple audio* mpeg2 editor
By febefe in forum EditingReplies: 1Last Post: 5th Sep 2009, 18:05
