Hello. I've just started using MultiAVCHD to burn video from my HD camera--a nice, easy to use program with good results, especially for rookies.
My problem: I chose my own static background .jpg image for the main menu, and it looks squashed when playing back (the ratio is wrong). Is there some way of making the pic show up on the background menu as it should look? It looks fine when viewed as a picture.
Thanks for any help. I assume there's an easy fix, but I can't figure it out.
What's the picture's resolution? If it's not some 1.78:1 ratio such as 1920x1080 or 1280x720, you may get that. Just a guess as I've never used that program. If it isn't the correct ratio to begin with and you want to keep the same picture at the correct ratio, maybe add a colored background to fill in the extra space.
The width is 1704? If so then there's your answer. Either add black to the sides to make it the correct aspect ratio, or crop it down. And unless it's 1920x1080, I think I'd probably resize it myself, rather than let MultiAVCHD do it.
A simple picture resizing did the job. Thanks for pointing out the obvious (though not obvious to me)...
multiAVCHD menu background and chapter thumbnail creation
By Delta007bhd in forum Authoring (Blu-ray)Replies: 12Last Post: 7th Dec 2016, 09:19 -
multiAVCHD Menu
By catracho2009 in forum Authoring (Blu-ray)Replies: 11Last Post: 29th Aug 2016, 18:18 -
multiAVCHD menu problem
By Clydesdale in forum Authoring (Blu-ray)Replies: 2Last Post: 4th Oct 2013, 23:36 -
TMPGEnc-menus background going to green screen or previous menu background
By DwightFry78 in forum Authoring (DVD)Replies: 0Last Post: 31st Jul 2013, 15:11 -
MultiavcHD menu problem...HELP!
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 7Last Post: 12th Jan 2012, 07:06
