  1. Member yoda313's Avatar
    Jun 2004
    The Animus
    I am considering buying cyberlink powerproducer 6 for my new bluray burner I just bought.
    Does it do any reencoding of level 4 h264 files?
    Specifically any created by the hauppauge hdpvr 2? (I have the gaming edition plus model 1504)
    I haven't bought any authoring software since tmpengc dvd author 2 so I'm a bit out of the loop.
    I know that tda 2 wouldn't reencode any dvd compliant mpeg 2 files. Does powerproducer 6 also leave bluray compliant files alone?
    Here are the specs for the captured file from a hdpvr2 (my dvr out is set to 720p fyi):
    Complete name : D:\caps\HDPVR2_20140314_2029.ts
    Format : MPEG-TS
    File size : 38.0 MiB
    Duration : 21s 313ms
    Overall bit rate : 14.9 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : 27
    Duration : 21s 121ms
    Bit rate : 13.8 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 59.940 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.249
    Stream size : 34.6 MiB (91%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : 129
    Duration : 21s 345ms
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : -654ms
    Stream size : 1 001 KiB (3%)
    Would this be reencoded by powerproducer 6?
    I wouldn't want any unnecessary encoding if I can get away with it. I'd like to plug it and make my menus and all of that jazz.
    Thanks for the suggestions.
    And if powerproducer 6 does reencode please kindly suggest a bluray authoring package that would create menus without reencoding the above file (I'm looking to not spend over 50.00 usd or around there).
    Thanks.
    Edit - just to clarify I am going to make BLURAY DISCS (not avchd and not simply a data file burn) from the above captured file (well more like them not that particular test file).
    canada
    Try multiavchd,it does menus,i wouldn't use or buy any cyberlink since it's crap and they use cinavia in their software player.Can you send a short clip to see what multiavchd does with it.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    It did it with a 20 second clip. There was a mention of transcoding somewhere even though I swear I didn't click the transcode button on the video tab of multiavchd. IT might have been for the menu only. Here is the log file -
    [17:08:33] Initialising...
    [17:08:33] Checking for new version...
    [17:08:34] You have the latest build.
    [17:08:34] [04/07/2012] build 771 (latest is: 771) - Few minor fixes (runtime/line 109 errors). Changed handling of some rare flavours of video in MP4 container.
    [17:08:34] Consistency check finished!
    [17:08:34] Initialization finished. multiAVCHD is ready!
    [17:08:34] 5 years and 80 days since multiAVCHD was published.
    [17:08:34] 548 people supported it with donations
    [17:08:34] and you are the 51228 one to launch the program...
    [17:08:34] Support multiAVCHD to extend its features and keep it going!
    [17:08:34] multiAVCHD.dat version: [04010767]
    [17:09:20] Enable the option to create menu first! (AUTHOR tab)!
    [17:09:22] Enable the option to create menu first! (AUTHOR tab)!
    [17:12:15] Checking for available space and drive types (FAT32/NTFS)...
    [17:12:16] Destination [D:]: NTFS, 188770.38 MiB (184.346 GiB) free space
    [17:12:16] Temp folder [D:]: NTFS, 188769.38 MiB (184.345 GiB) free space
    [17:12:16] Log started for multiAVCHD v4.1 (build 771)
    [17:12:16] Selected output mode: Blu-ray player (BD-R/BD-RE disc)
    [17:12:16] Processing one title...
    [17:12:16] Processing (D:\caps\HDPVR2_20140314_2134.ts)...
    [17:12:17] Detected frame reference count: 3 (max:6).
    [17:12:17] Detected video: ID#4113:V_MPEG4/ISO/AVC 1280x720, fps=59.940, ref=3
    [17:12:17] Adding AC3 audio track (ID#4352)
    [17:12:17] Total of 2 tracks found in this file.
    [17:12:17] Creating clip and playlist info (tsMuxeR)...
    [17:12:17] Media split set at 4000MiB point...
    tsMuxeR (Version 1.10.6) output:
    Decoding H264 stream (track 1): Profile: High@4.0 Resolution: 1280:720p Frame rate: 59.9401
    H.264 stream does not contain fps field. Muxing fps=59.9401
    Decoding AC3 stream (track 2): Bitrate: 384Kbps Sample Rate: 48KHz Channels: 6
    H264 bitstream changed: insert pict timing and buffering period SEI units
    Processed 1319 video frames
    Creation of Blu-ray playlist
    Creation of Blu-ray stream info and seek index
    Mux successful complete.
    Muxing time: 1 sec
    tsMuxeR meta:
    MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000 --split-size=4000MiB --vbv-len=500
    V_MPEG4/ISO/AVC, "D:\caps\HDPVR2_20140314_2134.ts", insertSEI, contSPS, track=4113, fps=59.940
    A_AC3, "D:\caps\HDPVR2_20140314_2134.ts", track=4352, lang=und, timeshift=-673ms
    [17:12:19] Media transfer: 00000 -> 00000.m2ts
    [17:12:19] Processing playlist...
    [17:12:19] Title #1 added: "HDPVR2 20140314 2134"
    [17:12:19] Verifying title...
    [17:12:22] Title has: 1 audio tracks and 0 subtitle tracks
    [17:12:22] Preparing authoring information...
    [17:12:22] Creating NTSC top menu.
    [17:12:22] Setting pop-up menu...
    [17:12:23] *** [00000.mpls] - Adding pop-up menu [1080p]...
    [17:12:23] *** Completed!
    [17:12:23] Authoring menu (NTSC).
    [17:12:23] Creating title thumbnails for 1 titles (XMB)...
    [17:12:26] Using 1 thumbnail/chapter links for title #1...
    [17:12:26] *** Extracting 1 chapter thumbnails...
    [17:12:26] *** Chapter #1 [00:00:00.000] set for thumbnail at [00:00:10.966]
    [17:12:27] Image processing for XMB menu completed!
    [17:12:27] Preparing menu pages...
    [17:12:28] Encoding static XMB menu page [1/1] [Static title thumbnail].
    [17:12:52] Encoding static XMB menu page [1/1]: Chapter page [1/1].
    [17:12:56] Encoding static XMB menu page [1/1]: Setup page (audio/subtitle).
    [17:12:59] Menu authoring completed.
    [17:13:00] Encoding Title List menu page [1/1].
    [17:13:17] Setting main menu for 1 titles...
    [17:13:17] Playback will end after title #1.
    [17:13:17] Setting menu properties...
    [17:13:17] Selected TV system: [NTSC]
    [17:13:17] Processing clip (CPI/CLPI) files...
    [17:13:18] Completed.
    [17:13:18] Setting Blu-ray format...
    [17:13:20] Done!
    [17:13:20] Saving multiAVCHD quick-load project (mpf):
    [17:13:20] D:\AVCHD\multiAVCHD.mpf (OK!)
    Compilation summary:
    Format: Blu-ray player (BD-R/BD-RE disc)
    1. HDPVR2 20140314 2134 [00:00:22]
    Overall duration : 00:00:22
    Output size : 53 MiB (0.052 GiB)
    [17:13:20] D:\AVCHD folder created (AVCHD/Blu-ray output)!
    [17:13:20] Burn its CONTENTS to BD-R/RE UDF 2.50/2.60 disc!
    [17:13:22] You may now remove temp folder (D:\tempmultiavchd\multiTEMP-20140315\).
    [17:13:22] Your compilation contains 0hrs 0min 22sec of video material.
    [17:13:22] multiAVCHD finished in 66.11 seconds (00:01:06.110)!
    [17:13:22] End of log.
    So does this mean it DID NOT transcode the original h264 file?
    I got a basic menu and I did not do any chapters since it was so short.
    canada
    It wasn't encoded,you will get a message if the file need to be re-encoded.
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    Sounds good. Thanks for reminding me about it. Since it was abandoned I forgot about it.
    I'll give it a go and burn with imgburn.
    I already did a successful tsmuxer bd folder from a full hdpvr2 cap. It plays perfectly on my ps3.
    Sent from my Nexus 7 using Tapatalk
