deleted. Can a mod please delete this thread?
I want to experiment some more and then make a thread thats explained in detail about the topic.
A duplicate every 6th frame indicates a PAL source (25 fps) converted to 29.97 fps. You would decimate back to 25 fps to eliminate the duplicate frames. If you're making a DVD and need 59.94 fields per second interlaced video you can apply 3:2:3:2:2 pulldown flags with DgPulldown after encoding as 25 fps progressive with an NTSC frame size, 720x480. I don't know if AviDemux can do all this.
You should upload a short (10 to 30 seconds) sample with moderate motion for more precise analysis. -
Thanks for the replies. Can a mod delete this thread?
Do I need to encode at 29.97fps?
By jnyfive in forum Video ConversionReplies: 4Last Post: 19th Jul 2013, 11:04 -
24fps or 29.97fps ???
By RodNichols5 in forum Capturing and VCRReplies: 29Last Post: 27th May 2011, 17:26 -
25 or 29.97fps?
By pooksahib in forum Video ConversionReplies: 6Last Post: 16th Jan 2011, 16:54 -
Help with HD @ 29.97fps to DVD at 25fps
By Killer3737 in forum Video ConversionReplies: 9Last Post: 19th Nov 2009, 14:29 -
1080p MKV files at 23.97fps - why?
By snadge in forum Video ConversionReplies: 0Last Post: 13th Jul 2009, 12:49
