I just discovered SVP it seems they updated POTPlayer and MPC - HC dition. The problem is I cannot get any of these programs to play a movie on 4 screens.
I can get 3 screens since NVidia surround makes 3 screens one, but my 4th is the accessory. Currently VLC can do it by stretching a video window onto all 4 or setting it up into "Wall Paper Mode"
Pot Player and MPC + SVP won't do it except on 3, there has to be an option (I tried disabling DXVA did not work) to allow for multiple monitor support. Anyone have any idea?
i.e
http://www.overpic.net/viewer.php?file=xusds8di6155wgzxkn99.jpg
I have USE DSXVA at the top and it does not list condition anymore but it has H264 compatibility.
I am curious though the main goal is I am trying to get this to work like VLC media player in wall paper mode ( I can set it up so that it puts video on all 4 of my 30" screens. Right now on 4 screens it only puts it on 3 due to nvidia surround, but in VLC it will do all 4.
system:
4 30" 1600p monitors
TITAN SLI
Love to get your input!
http://www.svp-team.com/forum/viewtopic.php?id=1891&login=1
https://forum.videolan.org/viewtopic.php?f=14&t=117729&p=399855#p399855
EDIT: 3 problems I reset it up and I got POTPLAYER + SPV to work on your max settings but I have a black on the bottom with POTPLAYER, I can view everything by adjusting the video with pan but was wondering if I had set something up wrong:
See the black bar on the bottom? With Pan/scan offset I can centerize it then make it full screen but images still of course take it with the black bar. I figure there is a setting I have wrong. Still wish I could get this on all 4 screens.
2 When I utilize PotPlayer Playback only it for some reason does not work with SPV with your settings, have you ever encountered that?
3 I am still not having any luck putting the image on all 4 screens. It seems to utilize the 3 screens in surround correctly but I cannot figure out how to set it up on the 4th. When it moves to the 4th it becomes blurred. This by far is the best player I have used with your settings I am just trying to get it to work on the 4th like VLC any ideas?
Full screen effect: in VLC (notice it is on all 4 screens)
This is how it looks with Potplayer or MPC when I move passed the 3 screens
If you notice there is the black bar on the bottom (seems to only show up in Potplayer.exe not mini version) + the distortion on the right screen where I try to extend it
Edit 2 I did some editing and checked to see if any change would happen if I activated all displays and not putting it into Surround. It seems that Media Player Classic and PotPlayer have difficulty processing the other screens unless windows sees them as (1) screen. For example on All Displays when you try to expand the player it blurs the video on the other screen. However, VLC did not have this issue. It's really annoying since the features of PotPlayer are AMAZING. I went back to surround and have the black bar on the bottom still but I have not found a solution to it not showing video on more than 1 monitor (in my case 2 since Nvidia sees 3 as 1)
I also had posted on the SPV forums as well:
http://www.svp-team.com/forum/viewtopic.php?pid=40895#p40895
			Closed Thread
	Why two similar threads? Continue in https://forum.videohelp.com/threads/362769-Pot-Player-with-4k-%284-monitors-1-surround-...99#post2307699
  Multiple Monitors?By therock003 in forum ComputerReplies: 1Last Post: 23rd Jan 2013, 09:02
  Problem with monitorsBy ROBO731 in forum Newbie / General discussionsReplies: 6Last Post: 3rd Dec 2012, 15:12
  Monitors and colour.By dfgh11 in forum EditingReplies: 3Last Post: 6th Jan 2011, 11:44
  Dual Monitors helpBy Cragsterboy in forum Newbie / General discussionsReplies: 4Last Post: 3rd Oct 2009, 11:20
  Dynamic Resolution PC Monitors vs TV Monitors Static Resolution.By therock003 in forum Newbie / General discussionsReplies: 24Last Post: 17th Apr 2009, 09:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
