Results 1 to 21 of 21
  1. I don't know. You have to be in Vietnam to view it. The site is very, very, very good at detecting proxies, so not many people here will be able to help you.
  2. Originally Posted by transporterfan View Post
    you can user proxy
    http://www.xroxy.com/proxy-country-VN.htm
    and help me
  3. I have tried it with FOUR(!) VPN connections...it identified all of them as not my true IP. I give up on trying to connect.
    To download the stream the best software to try is most likely https://www.videohelp.com/tools/RTMPDump.
    Good luck.
  4. I managed to connect eventually...nothing I have can read the streams. The player is a SWF player.
    If the handshake fails in RTMPDump (as you have indicated) I have nothing else to suggest. Sorry.
  5. all tool not work
  6. Last edited by em_dai_kho; 10th Mar 2014 at 20:36.
  7. The server digest holds a predefined security hash key. If you request access to the data (video) and you don't know the key you are kicked off. RTMPDump (and everything else it seems) cannot resolve the key. No connection. Ever. Full stop.
    To make matters worse it's played through a SWF player. Which means the player and video (embedded) may load as one packet.
    There is, in all likelihood, no stream to capture. Just because you see vod and an MP4 file name doesn't mean the data transmission isn't encrypted in some way.
  8. you can find token for me
  9. Nope. Try a screen recorder.
  10. Originally Posted by transporterfan View Post
    I think that's the worst solution
  11. You have a better suggestion?
  12. i think wrong token....
  13. edit ..........................................
  14. Deceased
    Dec 2007
    it is rtmpe w/token (and perhaps something more ??)
    getflv works if "enable rtmp record mode" box is checked.
    see result of download using getflv w/rtmp record mode: phuong_nam_005_2_high
  15. Originally Posted by blimey View Post
    where?
  16. Deceased
    Dec 2007
    edit:
    I see the box in your image of getflv program.
    It is to the right of "IE Kernel" after url address bar.
  17. Originally Posted by blimey View Post
    edit:
    tool download very slow ^^
  18. Deceased
    Dec 2007
    edit:
    It is saving from the stream to the flashplayer, as it plays. So, it can only go so fast as the flashplayer can play the file.
    This is a way around the token, since the flashplayer already has authenticated.
    But if someone provides the token and a good rtmpdump command line syntax, that method will be preferable. I didn't spot a token in the vivoPlayer25.swf disassembly or in system memory. Sorry.
  19. Originally Posted by blimey View Post
    thank you help,
    who can write command line ????
    i think token this: (S#adE%h0P#w@H2$%
    but not work.
    pls see attachments
