I have two VHS tapes that I would like to convert to VCD...
1) A collection of music videos
2) my wedding video (awwww)
I have been reading about the different FPS's of NTSC and NTSC Film. How do I know which one of these my VHS tapes are? Is this something that can only be discovered by trial and error? Any help would be appreciated. Thanks!
You Video on VHS should be 29.97 fps NTSC.
Flim rate NTSC video are normally from ripped DVD,
which was processed as flim, and converted
to either flim rate PAL or NTSC. -
Yes all ntsc vhs tapes are in 29.97fps. You could possibly do an inverse telecine after you capture your video but that depends on how it was originally filmed. Its worth a try, the results will be much better. You can use TMPGenc to do an inverse telecine.
ridgexyz,
Both your VHS tapes and your wedding videos will be 29.97, however, you might be able to do an inverse telecine of your VHS tapes and encode them as NTSC FILM. This will give you about a 20% increase in quality, but your source video has to be telecined. A basic test to determine if your video source is telecined is to find a scrolling scene (I find these are best for testing) in your captured video and scroll through the frames and see if you find a pattern of 3 progressive frames and then 2 interlaced frames. If so, then your video is most likely telecined and can be inverse telecined. For more info on telecine and inverse telcine, check out http://www.geocities.com/lukesvideo
If you do decide to IVTC your video, I would recommend using the Decomb filter for AviSynth. I personally believe it is the best IVTC filter out there. You can find it at http://www.doom9.org
Also, your wedding videos will not be telecined.
Using NTSC (16:9) and PAL (4:3) sources to restore a film...
By takearushfan in forum RestorationReplies: 61Last Post: 3rd Mar 2012, 16:13 -
NTSC/PAL but exact film length: How so?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2010, 12:42 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
Question regarding NTSC Film DVD
By txporter in forum Video ConversionReplies: 14Last Post: 30th Nov 2009, 10:29 -
FPS NTSC & PAL Film/Digital
By flamingo in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 14:21
