Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 30 of 30
  1. Member yoda313's Avatar
    Jun 2004
    The Animus
    Just an fyi for others who may be interested. I finally bought my new tablet I've been waiting to get.
    I bought the 16gb Google Nexus 7.
    It's a 1.5ghz quad core tablet.
    I had to download the bsplayer free edition to play this test file but it played it perfectly:
    Matroska
    Format version : Version 2
    File size : 397 MiB
    Duration : 23mn 41s
    Overall bit rate : 2 343 Kbps
    Encoded date : *******************
    Writing application :**************************
    Writing library : ***********************
    Attachment : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
    Video
    Format : AVC
    Format profile : High 10@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 16 frames
    Muxing mode : Header stripping
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 23mn 41s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 10 bits
    Scan type : Progressive
    Writing library : x264 core 133 r2334 a3ac64b
    Encoding settings : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=12 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Default : Yes
    Forced : No
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 23mn 41s
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Delay relative to video : 9ms
    Default : Yes
    Forced : No
    Text
    Format : ASS
    Codec ID : S_TEXT/ASS
    Codec ID/Info : Advanced Sub Station Alpha
    Compression mode : Lossless
    Default : Yes
    Forced : No
    My previous no name cheapo tablet would have chocked and refused to play this file. But the nexus 7 fired it up right away and played it perfectly.
    This is only the first hi10 file I have tested so far so there may still be some in my collection that may have to be reencoded. But I am very satisfied with my purchase.
    Hopefully this will be useful to someone in the future. If you can get a tablet with equivalent specs as the nexus 7 (the one currently available in stores as of March 2014) you can play hi10 h264 video files without the need to reencode them to 8 bit files.
    This will save me lots of time and headaches in the future.
    The only weird thing was the superhd player isn't preinstalled on the nexus 7. It was installed on my no name tablet, android 4.1 I think it is.
    Oh and the best thing is it came with android 4.3 but I was able to upgrade to 4.4.2 right away straight from the tablet itself. No problems at all.
    I definitely like it a lot so far and the screen is very vivid. And the speakers are really good too. My no name tablets speakers were so weak I always used headphones with it.
    And I finally have a tablet with bluetooth so I can use my cordless bluetooth headphones with it.
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Could you post the file? I'm curious if my old Asus 7" dual-core can play it. I'm thinking it can..........
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Sorry I'd rather not.
    If its a dual core tablet I will guess it can't handle hi 10. Just search the net for hi10 h264 or encode a sample from a hd file you have on your computer. Just use ripbot264 or megui and you are all set.
  4. Member racer-x's Avatar
    Mar 2003
    It played, but not at full fps................
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    It might not help but you could try bsplayer or mxplayer. Both have hardware encoder modes that are supposed to play hi 10 files. But I didn't have success with them on my old tablet. That's why I got the nexus 7.
  6. Member racer-x's Avatar
    Mar 2003
    I used MoBo player. It's free and lets you choose between H/W or S/W decoder. I let it use H/W decoder and it played it at what looked like 15 fps when it should have been 24 fps.
    Oh well at least this 1 GHz dual-core can play full 1080p @ 24 fps h.264, 4.1 or lower.....
  7. Member yoda313's Avatar
    Jun 2004
    The Animus
    That's too bad.
    As I mentioned that's why I upgraded. I didn't want to convert anymore.
    It turns out bsplayer is only playing in software mode not hardware mode. But it's doing it at what appears to be close to the original frame rate so there is no noticeable slowdowns or dropouts. So Im definitely happy with the two test files I've used so far.
  8. I'm a Super Moderator johns0's Avatar
    canada
    My ASUS Memo Pad HD 7 played this test file with mx player.
    General
    Unique ID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    Complete name : D:\[720p][16_REF_L5.1]test.mkv
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 56.0 MiB
    Duration : 1mn 32s
    Overall bit rate : 5 075 Kbps
    Encoded date : UTC 2010-02-22 21:41:31
    Writing application : mkvmerge v5.9.0 ('On The Loose') built on Dec 9 2012 15:37:01
    Writing library : libebml v1.3.0 + libmatroska v1.4.0
    Video
    Format : AVC
    Duration : 1mn 32s
    Height : 720 pixels
    Frame rate : 1 000.000 fps
    Original frame rate : 23.976 fps
    Color space : YUV
    Bit depth : 10 bits
    Default : Yes
    Forced : No
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 1mn 32s
    Delay relative to video : -425ms
    Default : Yes
    Forced : No
    Text
    Format : ASS
    Default : Yes
    Forced : No
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    you guys really should update your mkvtools and use the new version to remux without header stripping. and does bsplayer or mxplayer handle dts audio on the tablet ok?
  10. I'm a Super Moderator johns0's Avatar
    canada
    No need to update mkvtools since it's for osx,also this is for testing on android tablets so head stripping isn't an issue,head stripping is a problem for blu-ray players.To plays video with dts audio you need to download the codec for it.
  11. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    header stripping causes problems with any software that doesn't acknowledge it. it's a part of the mkv spec that wasn't well received and died a timely death.
    how about dts in mx player on android?
  12. Member racer-x's Avatar
    Mar 2003
    Hey Yoda, let me know if you can play this HEVC 720/24p x265 file. I don't care about High-10 because I never use it, but I may use hevc in the future. It would be good to know what can play it. Mine tries to play it, but only gives black screen.
  13. Member yoda313's Avatar
    Jun 2004
    The Animus
    The bsplayer free edition played it perfectly in software mode.
    Mx player only played the audio no video.
    The stock player didn't play the video, just the audio.
    I don't have a dedicated x265 player for android so I don't know if there is hardware support for it yet. If its software only right now you'll have to have a fast tablet to decode it in software mode from the looks of things right now.
  14. Member racer-x's Avatar
    Mar 2003
    So you were able to play it at full framerate on your 1.5 ghz quad-core tablet? That's good to know.....
  15. Member yoda313's Avatar
    Jun 2004
    The Animus
    Well I don't know if it was a 100% full framerate. It might have been lower. But it was not perceivable to me if it was lower than the original rate. I don't know if bsplayer has a frame rate display while a video is playing.
    If someone knows for sure I could do that and test it again while that file is playing.
  16. Originally Posted by racer-x View Post
    I tried it on Samsung Galaxy Note 10.1, 1.4 GHz quad-core processor and it played that HVEC, that was surprise, average 19fps (18fps or so streaming over LAN) , so almost there ...
    press that "i" at the bottom,..., that bsplayer for Android seems to be much better than MXplayer, as for playing Hi10, HVEC or DTS even ...
    that bsplayer plays DTS also
  17. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    the hvec file plays at 23.87fps here on the nexus 7 2013 or over wifi. i couldn't find anything but bsplayer to play the video either, not even the latest vlc beta.
  18. Member yoda313's Avatar
    Jun 2004
    The Animus
    Thanks. Yep I got 23.8 to 23.9 like aedipuss. Strange that it says the frame rate is 24 even but it ranges from 23.x to 23.9. But like I said there wasn't any issues from a visual standpoint, even if its not a 100% perfect, which I guess it is.
  19. Member racer-x's Avatar
    Mar 2003
    Thanks for trying it out guys. From the responses, it looks like you need at least a 1.5 ghz quad-core to play a 720p hevc file. I'll have to keep that in mind when I want to upgrade.
  20. Member yoda313's Avatar
    Jun 2004
    The Animus
    I'd wait for the next model change by samsung or google. Than you should be able to get this current generation of quad cores at a reduced rate.
    I didn't want to wait anymore to upgrade my tablet experience.
  21. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    google is eliminating the current 7inch and going 8 and 10 for the next gen.
  22. Member racer-x's Avatar
    Mar 2003
    It'll be a while before I upgrade anyway. I really like my little 7 inch Asus MemoPad. I got it on sale for $80 USD last year, can't go wrong and it's more than proven it's worth.
  23. Member yoda313's Avatar
    Jun 2004
    The Animus
    Just thought I'd mention I can finally use the vudu app! All my ultraviolet movies are now available on my tablet. My speed is great and no stuttering.
    I just watched part of star trek into darkness and it looks and sounds great.
    I'm liking this even more now.
    Sent from my Nexus 7 using Tapatalk
  24. Member racer-x's Avatar
    Mar 2003
    NewEgg is selling the Google Nexus 7 HD 2013 1.5 ghz quad-core refurbished for $144 usd after rebates if anyone is interested...............
    http://www.newegg.com/Product/Product.aspx?nm_mc=AFC-TechBargains&cm_mmc=AFC-TechBarga...82E16834231555
  25. Member yoda313's Avatar
    Jun 2004
    The Animus
    For some reason usb otg is not enabled on the nexus 7. I have a otg cable but it won't work by itself.
    After digging around I found a 4.00usd app called nexus media importer. It will read usb otg devices without needing to root the unit.
    Only trouble is at the moment I think it only does file transfers. I don't know how to use it like a regular old sd card on my old tablet. I can't seem to select a file and launch it with an app. I mean like looking at a folder of video files and loading it into a video app without saving it to the tablet first.
    This is nearly great if I can figure out how to read from it without copying.
    It will still be cool as I can copy to the device without having to boot up a computer. I just have to connect the harddrive and go. But it seems like it's only powered usb drives. I have a 500gb seagate drive that just kept doing nothing while a 2tb powered western digital drive was read right away.
    If I can figure out how to watch or listen to files off of a usb drive with this program without copying them to the tablet first this will solve my lack of a sd card issue.
    I do recommend this program so far even with its apparent limitation. And 4.00 isn't bad either.
    If I can figure out how to essentially "stream" from a usb (ie play without copying to the tablet first) I'll report back.
    EDIT - YOU HAVE TO GO TO VIDEOS AND THEN YOU CAN "STREAM" FROM THE USB DRIVE!!!
    Yep click videos and then you get your file list - then select the file you want and it will let you play it with any of your video apps.
    GREAT PROGRAM!!!!!!!
    AWESOME!
    Edit - I didn't realize that in the folders tab section you can still launch the video file without copying it.
    Even better so you can browser your folders unlike the awful file list view of the "videos" tab. Just select "folders' and then select the file you want and in the right panel you can press it to launch your video app.
  26. Why not to use wi-fi for streaming? Es File Explorer with Bsplayer for example could be only apps you might need for that. With those small mobile devices it is kind of clumsy to be wired to large storage of some sort.
  27. Member yoda313's Avatar
    Jun 2004
    The Animus
    Actually I use headphones while watching anyway so I already have a cable, no biggie.
    I do have Bluetooth ones but they were uncomfortable after awhile.
    Besides I don't have to do any networking this way. Just having the two units on will be good.
  28. Member racer-x's Avatar
    Mar 2003
    I don't think I would buy a tablet without a micro SD slot. 32 GB card holds a lot of videos, photos and music.
    What I would really like to do with my little tablet, is convert it into an external monitor/controller for my DSLR. Unfortunately every app I tried so far has failed.....
  29. Member yoda313's Avatar
    Jun 2004
    The Animus
    I thought I'd mention I finally have a smart device with a auto focus camera. I can now use those barcode scanning apps.
    I have the my movies app. I had to manually add them. Now I can scan the barcodes.
    This is fun.
  30. Member yoda313's Avatar
    Jun 2004
    The Animus
    I thought I'd update this thread. I bought some no name Bluetooth over the ear headphones.
    I really like them. They are Bluetooth 3.0 but the nexus is 4.0. I don't think I'll lose out on any 4.0 features since I'll only be using it for listening to movies/TV shows, not making calls.
    I'll also be streaming vids from apps or my ouya via xbmc or my PC via playon.
    Point is I'm finally 100% cordless now.
    I was using wired ear buds before.
    I'm curious, how much does Bluetooth tax the battery?
    I'll be at home with these so charging won't be a problem.
    I've love my nexus!!!!
    Edit
    I have some behind the ear Bluetooth headphones but watching a video longer than ten minutes is painful if your laying down. It has the hard plastic band which bites into your neck.
