Hello,
I'm trying to capture the signal from the cable TV box I have with a Hauppauge HD PVR, but no success so far.
Here is the box I have:
And here is my connection, a Scart to Composite video, from the box to the HD PVR. What's wrong?
				Results 1 to 22 of 22
	PC - Working perfectly. An Asus K55VM-SX083V. All software and drivers installed.
 HD PVR - working fine too, already tested with a Playstation 2, with the same method: composite out of the PS2 to the HD PVR (with this cord). The signal was captured with success.
 Cable TV box - the problem could be here, but I don't think so. I've read some guys able to get the signal off the box via scart/composite.
 I think the problem is the cord I'm using between the TV box and the HD PVR:
 Because I'm not sure this cord even works. Is it possible that this cord only carries a signal from Composite TO Scart and not from Scart TO Composite? I think the problem could be this.
 To test if it worked, I connected the Scart side in the TV Out of the TV box, and the Composite side in the front panel of my TV, which has a Composite entrance, and it didn't work.
	Yes, that's possible. SCART uses separate pins for composite input and composite output. So there are different adapters for sending composite to a SCART device, and for getting composite output from a SCART device. Some adapters have a switch that allows them to be used either way.
 It's likely that you need the other type of SCART/composite adapter cable. But just to be sure, make sure your TV box doesn't have a setting that disables the SCART output. Also try removing any HDMI devices from the cable box -- some boxes won't output HDMI and analog at the same time.
	example of a bidirectional adapter: http://www.amazon.co.uk/Switchable-Scart-Phono-S-Video-Adaptor/dp/B0018DE4ZU/
 By the way, try the s-video output if you can. It may provide better picture quality.
	You could try remuxing to a container that supports AR flags and set the flags to 16:9. MMG, part of MkvToolnix for example. Or you can demux the h.264 track, use H264 AR Changer to change the existing flags in the h.264 stream, then remux with the audio.
	From looking at your photo it seems that the HD PVR is correctly recording a full screen 4:3 image as 4:3. Hauppauge's devices aren't really set up to allow you to stretch standard definition 4:3 to 16:9. If you want a 16:9 recording then you need to have a 16:9 source. If you're good with AviSynth you could properly record it as 4:3 and then re-encode it to 16:9 after you crop some of the video to get it to 16:9. AviSynth will also happily let you just stretch it from 4:3 to 16:9 if you wish (ugh).
	The HD PVR probably doesn't respond to the PAL widescreen flag in the analog signal. Or mabye the cable box isn't setting it.
	It depends. If you need to play your videos on an AppleTV, PS3, or Xbox 360, use MP4. If you don't want to be bound by the dictates of Apple, Sony, and Microsoft, use MKV as it's generally more flexible and pretty well supported these days (I always use MKV now, all my players support it). If you're broadcasting video over the air use TS.
	I'm concerned with Sony Vegas. I use the program a lot, and I can't directly import a .mkv file.
 Is there any loss of quality converting from mkv to ts and vice-versa (with mkvmerge and tsmuxer)??
 Another issue: with mkverge i managed to convert from 4:3 to 16:9, but with tsmuxer I couldn't, the video remained in 4:3. What am I doing wrong?
	Yes, I can do that, but I would like to send some of my captures to other people who will just watch them in the players, not edit, so i need them in 16:9.
 The problem is:
 1) if it's a .mkv, the AR is correct, but can't import to Vegas directly
 2)if it's a .ts, the AR is wrong (I'm not managing to change it to 16:9), but I can open it in Vegas.
	I hate to suggest it, but MP4 supports aspect ratios.
 If you demux the h.264 video you can try using H264 AR Changer to change all the AR flags in the stream -- if it has any. Unfortunately, it can't add AR flags if the stream doesn't already have them.
	I think I will just stick with this:
 1) capture in TS (can only capture in TS, MP4 and AVCHD)
 2) convert to MKV (but keep the TS one also)
 3) send MKV to the people I want (AR correct)
 4) import TS to Vegas when I want, and force to 16:9
 Thanks for all the help, really! Very very useful!
	TS files will compress by about 5 percent if you ZIP them. Otherwise, you have to reencode with a lower bitrate.
  Capturing a cable signalBy ScottP in forum Newbie / General discussionsReplies: 2Last Post: 26th Feb 2013, 09:18
  Capturing 720p HD HDMI signal via Blackmagic Intensity wierd interlacing?By TermiATT in forum Capturing and VCRReplies: 22Last Post: 1st Jun 2010, 13:31
  Capturing SD 4:3 Movies with HD PVRBy turbines in forum DVB / IPTVReplies: 2Last Post: 23rd Apr 2010, 08:46
  Card for capturing HD Component SignalBy peez in forum Capturing and VCRReplies: 4Last Post: 10th Nov 2009, 10:42
  Any OTHER S/W for Capturing a DH-PVR?By Randall_C in forum Capturing and VCRReplies: 6Last Post: 22nd Oct 2009, 13:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
