I-ve got a region free DVD player and I-m in Europe. If I play NTSC region 1 DVDs on it will the picture quality be the same as the region 2 DVDs? Do I need also a TV that plays NTSC?
thanks in advance m8s
EE
Yes to first question.
If your tv can display a pure ntsc signal then u should be fine.
If not your dvd player should have pal60 setting so you can watch ntsc on a pal tv in colour otherwise the picture will be in black & white.
David -
In my case (NTSC, North America), I use my DVD player's "auto" settings to detect if the disc is formatted as NTSC or PAL (I have a bunch of PAL VCDs), and set the output display as NTSC. Ever since I did that, I haven't had to switch settings back and forth, or see black-and-white, smushed pictures when watching PAL VCDs. It all appears as normal as native NTSC discs.
Good setup to copy NTSC tapes to DVD in Europe?
By Baree in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2012, 13:01 -
phone to use in europe
By MJA in forum Off topicReplies: 3Last Post: 7th Nov 2011, 17:13 -
Catpuring old NTSC tapes in Europe (b\w - color problem)
By Heartworm in forum Capturing and VCRReplies: 6Last Post: 13th May 2010, 20:25 -
Camcorder for USA and Europe, NTSC - PAL
By animaeme in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 17th Mar 2009, 07:29 -
Sony KDL 26S3000 NTSC to Europe's PAL
By Konstan in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2008, 12:12
