Hello.
So recently i made a DVD with some episodes on a Dual layer disc at about 7.81 gigs and it work fine with no problems.
So now i made one at 4.30gigs on a regular disc, i use Imgburn with no errors but when put in the DVD player it freezes close to the end of the first episode.
What do i do for this not to freeze i have 3 folders at 4.30 gigs with 3 episodes each, should i use a dual layer again?
				Results 1 to 13 of 13
	If it's not a Verbatim or Taiyo Yuden disc.....most likely it's the disc.
	Listen to hech54. It's probably a media error. Try to copy the contents of the disc to your hard drive and see if it gives you any reading error.
 And you can't just put the 3 folders on a DL. DVD-Video doesn't work like that."The greatest trick the Devil ever pulled was convincing the world he didn't exist."
	The first 2 discs worked so good and i used dual layer, i had to split the cells tho.
 I have to try and find them dvds then around here.
	If you think you already know the answer, why bother to ask? "The greatest trick the Devil ever pulled was convincing the world he didn't exist."
	Thanks.
 So when i want to try 4.7 again are these good ones?
 http://www.officemax.com/technology/drives-memory-storage/cds-dvds-and-data-storage/dv...Q9K1ZlcmJhdGlt
 only ones i can find in stock near me...
 and its about 3.5 hour's a folder will that be okay even tho it say's 120 mins?
	At this point given that it's 2013, I really don't know what we can do to help people like this who flat out refuse to buy anything online and will only buy what they can find in local physical stores.
 Dude - Do you or do you not want good discs? Or will you just take the best of the crap your local store has to sell?
 You'll have to buy good Verbatim or Taiyo Yuden online. A few stores do sell good Verbatim (nobody I know of sells TY except online) but most sell the dreaded "Life" series, which is what you found. It sucks. It sucks less than your Memorex for sure and probably less than most other brands you can find in a physical store, but it's still subpar cheap media intended for Americans who don't care about quality and want to pay less money for lower quality discs. Verbatim makes the Life series for people like you who only go to physical stores and don't buy online, but it's still cheap crap, just less crappy than most/all of its competitors for "value conscious" consumers. Verbatim makes a ton of discs, the vast majority of which are great, but they had to make the Life series because they were losing too many sales to customers who felt that only suckers paid more for discs. Sadly, one of the things I have learned in recent years is generally most Americans will gladly pay less money for a crappier product, but they hesitate to pay more for a better one. Verbatim can sell to those people too on the budget side, but the buyers sacrifice some quality compared to their excellent media. Anything that Verbatim makes that does NOT have the "Life series" label on it is first rate.
	No. Verbatim's Life series is also low quality. You want Verbatim Datalife or Datalife Plus, or Taiyo Yuden. Order them from Amazon.com or supermediastore.com if you can't get any locally (and you probably can't, anymore).
 You can put as much running time as you want a single layer DVD because:
 The issue is at what bitrate does the video become unwatchable because of the loss of detail and blocky artifacts. 3.5 hours should usually be encoded for a dual layer DVD unless it's very clean animated material (which compresses pretty well). Another technique you can use is to reduce the frame size to 352x480 or even 352x240. In that case you are trading off resolution to get fewer compression artifacts. If your video isn't very sharp to begin with (VHS tape for example) 352x480 is often a reasonable compromise.Code:file size = bitrate * running time
  burnt dvd's dont play in my player!By StormBreaker in forum DVD RippingReplies: 8Last Post: 14th Apr 2013, 11:20
  burnt the avengers onto dvd disc but stuttersBy clactongirl2002 in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2012, 22:55
  Occasional Sound issues with a burnt DVDBy Al Slitter in forum Newbie / General discussionsReplies: 28Last Post: 17th Dec 2011, 18:45
  Burnt XVID looks awful on DVDBy skribby in forum Authoring (DVD)Replies: 5Last Post: 16th Aug 2009, 12:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
