Results 1 to 9 of 9
  1. I'm using version 8.6 In order to upgrade to 8.7 must I unistall the older version first? Also if I upgrade will my settings be retained?
    Thanks.
  2. I think you can just overwrite old files
  3. Personally I always run the 'uninstall.bat' then replace the old files with the new ones and run the 'install.bat' and unless you run the 'restore default settings.bat' all previous settings should be kept.
    (I suspect that simply overwriting the old files, should work too. )
    Jan 2014
    Kazakhstan
    MadVR, he turns HEVC 10bit in candy / good job filters
    (avoid EVR)
  5. Originally Posted by Gravitator View Post
    (avoid EVR)
    Jan 2014
    Kazakhstan
    (avoid EVR)
    You should come to his camp and understand what they're cooking / working very actively on progress to improve video > http://forum.doom9.org/showthread.php?t=146228
    (MadVR more lenient / filters optimized 10-bit space - purer; EVR rough texture transfers - dirt)
  7. I see that google translator works like charm again
    Jan 2014
    Kazakhstan
    Experiment with the settings and achieve additional visual quality
    Look at the left part of the costume (dark scene - a complicated scene)
  9. Originally Posted by Atak_Snajpera View Post
    Haha That didn't help me. Do you release MediaInfo Lite?
