Closed Thread
  1. Hi
    I'm trying to hardcode a srt file to a mp4 file containing h264 video. I open my video file and add srt file from subtitle menu and set format to "mp4" and I choose "copy" for both video and audio encoding. When I play the file in XviD4PSP5 subtitle is shown and every thing is ok. but when encoding is done the result mp4 file is not showing subtitles. Am I doing anything wrong?
    thanks
    You can't use copy mode if you want to hardcode . Choose a video codec.
  3. ok. how can I use the same video codec that the file is already in?
  4. Originally Posted by babak.y View Post
    Easy, just select it. If you hardcode subs you have to reencode, as Baldrick said. Why shouldn't you be allowed to choose the same codec?
  5. I used "Media Info" from "Tools" menu and it says:
    MediaInfoLib - v0.7.62
    General
    Complete name : H:\Film - Vahid\Frozen (2013) [1080p]\Frozen.2013.1080p.BluRay.x264.YIFY.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 1.63 GiB
    Duration : 1h 42mn
    Overall bit rate : 2 289 Kbps
    Encoded date : UTC 2014-02-27 06:26:54
    Tagged date : UTC 2014-02-27 06:26:54
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 1h 42mn
    Bit rate : 2 193 Kbps
    Maximum bit rate : 26.0 Mbps
    Width : 1 920 pixels
    Height : 856 pixels
    Display aspect ratio : 2.25:1
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.056
    Stream size : 1.56 GiB (96%)
    Writing library : x264 core 135 r2 f0c1c53
    Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2193 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
    Tagged date : UTC 2014-02-27 06:27:02
    Color primaries : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1h 42mn
    Bit rate mode : Variable
    Bit rate : 93.7 Kbps
    Maximum bit rate : 103 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 68.5 MiB (4%)
    Language : English
    Encoded date : UTC 2014-02-27 06:27:02
    based on this output, I donno which codec to use so that quality is same as the source after subtitles burnt to video. I don't want to change anything but hardcode subs to video.
  6. Originally Posted by babak.y View Post
    The quality will never be the same because you're reencoding. Set the audio to 'Copy' and under 'Video Encoding' choose x264 Q18 HQ. Set the format to MP4 and select the subs in Subtitles->Add. Encode. The size may be a little different but the quality should be similar to what you began with.
    Lucky you. Iran gets Academy Award winning films available before we in the US.
    Bamana Khoda!
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Buy the movie instead of downloading warez. Reread our rules.
    https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)?
