Hi everyone I need some help on choosing a video capture device. I dont know whats the best way for video capture.
I want to capture VHS/Laserdisc and maybe some TV shows. Would would be better for this a capture external device or a capture video card that I install into my pc. Also I want to try to get the best video possible without the capture device encoding it. Plz any suggestions Ive been
looking online and etc, but dont know which one would be the best for me.
Results 1 to 9 of 9
You might get more specific advice if you let us know what computer you're using.
You will need something more than a capture device and a single HDD. If you want to capture standard definition video as a losslessly compressed AVI, you will need a second internal hard drive to avoid dropped frames. To capture standard definition video as an uncompressed AVI you'll need a RAID 0 array or SATA III SSD. Making high definition TV captures in either of the above types of AV is more demanding. Most people employ lossy compression to capture high definition TV for that reason.
[Edit] USB 2.0 is enough to capture uncompressed or losslessley compressed SD video, and most of the devices that would allow you to do that use a USB 2.0 interface. To capture uncompressed or losslessley compressed HD video, you will need to look for an internal device. There are USB 3.0 devices for uncompressed or losslessley compressed HD video capture, but only a few specific USB 3.0 controllers are compatible, and they aren't used on most motherboards.Last edited by usually_quiet; 5th Mar 2014 at 13:07. Reason: more info & clarity
Okay thanks for the info because alot of captures encode to x264. what's a capture device that can either encode to a loseless codec or uncompressed?
Quite a few USB devices have the ability to do it, but you usually cannot do it with the software provided with the device.....my Hauppauge USB-Live2 for example. It can capture lossless via a program called DScaler easily, and supposedly via VirtualDub but I've never had much luck capturing with VirtualDub so I never tried it.
VHS: Get a good VCR first. If you can get an S-VHS deck, and capture through s-video, great. However, since this is 2014, finding a good used one has an ever fading probability. But you can get good quality from a good composite 4-head, HiFi deck.Originally Posted by JeffG89
Laserdisc: Capture using composite/RCA (the yellow one).
Good capture devices are the Hauppauge USB-Live2, ezcap.tv (the real one). If you can find an ATI USB 600, this too is a good choice.
TV Shows: This is open ended. A good capture device for TV is not necessarily good for VHS/Laserdisc, or vice versa. Example: Hauppauge USB-Live2 (good for analog capture such as VHS) and Hauppauge WinTV-HVR950Q (good for TV) - both would be much weaker in reverse roles (unless you capture TV in analog). Capturing in HD? Different animal altogether.
I wouldn't bother with internal for SD. Although they don't necessarily produce better quality, you may get better performance from an internal card with an older machine, but it's not an issue with yours. USB devices will be good enough. Those mentioned earlier are USB external.Originally Posted by JeffG89
Use lossless video formats, as was mentioned, like HuffYUV, Lagarith or UT.Originally Posted by JeffG89
Public info on capture devices is spasmodic at best. Only in Forums like these will you get the low-down on what's good or not.Originally Posted by JeffG89
Those three mentioned. They all work very well with software like VirtualDub. Don't know enough about DScaler to give more info on it.Originally Posted by JeffG89I hate VHS. I always did.
USB video capture device
By ManUtdFans in forum Capturing and VCRReplies: 5Last Post: 20th Aug 2013, 16:55 -
Using sony hi8 as video capture device
By Jim Jackson in forum Capturing and VCRReplies: 14Last Post: 3rd Mar 2013, 03:51 -
Best video capture device
By sanray19 in forum Video ConversionReplies: 8Last Post: 23rd Oct 2011, 15:04 -
Video Capture Device - Suggestions
By rancineb in forum Capturing and VCRReplies: 12Last Post: 20th Aug 2011, 19:27 -
Virtual video capture device?
By plugues in forum Video Streaming DownloadingReplies: 2Last Post: 13th Jul 2010, 19:28
