How do I rip and burn the Special features on a dvd. I use DVD2SVCD to convert my DVD to SVCD. Without any problems. Now I want to know how to rip the Special Features and Burn them. It doesn't do that.
Try useing Smartripper .. You can rip the special parts useing that by simply clicking on them in the Title -> Program Chain -> Angle section. :D
Good luck . -
thanks for replying. I am really new to this. tell me how do i know which of the files are the special features.
Two ways have worked for me:
1) Determine how long the special features are - by playing the DVD. Then launch Smartripper. It will tell you how long each title is, so you just pick the one that matches the length.
2) Usually you can open the VOBs in DVD2AVI directly from the DVD. It will be scrambled, but sometimes it's enough to tell which files are what. -
Thanks for your help. I'll try that now. how do i start smartripper. I have the things loaded and everything. but what do i do to make the process begin.
Can't find special features with DVD Shrink
By neworldman in forum DVD RippingReplies: 6Last Post: 9th May 2010, 00:56 -
how do i rip special features off a dvd?
By username1 in forum DVD RippingReplies: 4Last Post: 6th Apr 2010, 18:18 -
Can't access Special Features
By wulf109 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Sep 2008, 13:55 -
special sub+idx
By akusoul in forum SubtitleReplies: 6Last Post: 6th Apr 2008, 05:00 -
Features
By Jedi_Knight in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 29th May 2007, 18:29
