I guess some mistakes are hard to come back from.
I don't know where you get that from.
http://en.wikipedia.org/wiki/History_of_Internet_Explorer#2006_onwards:_new_competition
"Internet Explorer 7 was also available for download directly from Microsoft's website. Large amounts of the underlying architecture, including the rendering engine and security framework, had been completely overhauled. Partly as a result of security enhancements, the browser became a stand-alone application, rather than integrated with the Windows shell, and was no longer capable of acting as a file browser"
I don't understand why you can't grasp the distinction between not understanding and not agreeing.
So you've got to go to the trouble of disabling two bars with Firefox, therefore you use Chrome instead because you only need to disable one. Really??? That's an actual argument for using one browser over another? Really??
Wanting a sandbox is fair enough, but so far it's the only distinction you've managed to offer between the two browsers which makes sense.
Apparently you can't compensate for a few lost pixels by using the scrollbar, but when it comes to squishing a bunch of programs on a single screen, you and the scrollbar are bestus buddies.
Sometimes I run more than one window on a monitor. Sometimes I tile windows on both monitors. I just don't to do it as often with two monitors because I don't need to, but when I do I don't have to fuss about a program using a few extra pixels or bother the scrollbar incessantly.
https://helpdesk.malwarebytes.org/entries/23482988-What-are-the-PUP-detections-are-the...ey-be-deleted-
PUP detections are Potentially Unwanted Programs. These are programs our researchers have found are sometimes added to a system without the user's knowledge or approval.
The default action for PUP detections is 'Show in results list and do not check for removal."
Maybe if you'd mentioned what program Malwarebytes deemed unworthy to be installed on your PC and whether you checked what it was and decided it should be removed.....
Results 31 to 34 of 34
This from a guy who would be put off from using Chrome because one of the 6 buttons in its user interface is located where he doesn't think it belongs.
Our discussion started because you asked why I switched to Chrome. I told you. Unfortunately, it appears that nobody is permitted to want anything that you don't see the point of. I want what I want, and Chrome has it. Firefox doesn't. End of story. I'm done.
It was "PUP.Optional.InstallBrain.A" and it was something that should be removed [Edit]especially if I can't determine the source.[End Edit]
http://www.malwareremovalguides.info/tag/pup-installbrain/
http://spywareremovers.com/how-to-remove-pup-optional-installbrain-aLast edited by usually_quiet; 8th Mar 2014 at 12:29.
Our discussion started because I asked why has Chrome become so popular. You gave a few reasons you said made it easy for you to switch without actually stating they were why you switched, while I replied I couldn't imagine an extra inch of screen real estate could be the reason for a browser going from zero to the most used in such a short time. I know you switched because it has a sandbox and you imagined it provides more screen area for web pages. I still don't know why it's so popular, but I still doubt either of those reasons are a major factor. You can want whatever you want, but unfortunately it appears nobody is allowed to disagree with you.
That's the trouble with anti-malware programs. Often you can't tell whether the warning is legit or a false positive, and despite firewalls, anti-virus, and anti-malware, half the time you're trying to remove something which the anti-infection software should have protected you from the the first place.
Me.... if I became aware I was infected, I'd just restore the previous Windows image and be done with it. That fixes everything, and often in less time than it takes to clean an infected PC. -
Sometimes PUPs are included in adware and installed with a users informed consent for benign purposes. In other cases, PUPs have been re-purposed by hackers and installed without a user's knowledge for malicious purposes. The reason why Malwarebytes flags them as suspicious instead of deleting them automatically is that there is no way for it to tell if someone agreed to install them or not, or if they are being used for malicious purposes.
Security software can only detect and block threats it can recognize, so none of them is perfect because it isn't possible for any of them to block something that they weren't designed to look for. IMO If they can bock most harmful things and prevent the need to perform a time-consuming cleanup or restore an image they are still worth having. [Edit] The lock on my front door isn't perfect either. Someone who is determined to break in can still do it, or I could lock myself out by accident, but that doesn't mean that I'm just as well off with no lock at all .Last edited by usually_quiet; 8th Mar 2014 at 14:42. Reason: clarity
Will you even try Chrome OS when it arrives?
By ahhaa in forum ComputerReplies: 4Last Post: 14th Nov 2010, 12:50 -
Google Chrome
By HotDamn! in forum ComputerReplies: 2Last Post: 22nd Apr 2010, 12:33 -
live bookmarks for google chrome?
By gooberguy in forum ComputerReplies: 0Last Post: 17th Feb 2010, 10:13 -
special effects green chrome
By Fary4u in forum EditingReplies: 4Last Post: 1st Feb 2010, 08:18 -
How to save a video tutorial downloaded by Google Chrome
By avz10 in forum Newbie / General discussionsReplies: 3Last Post: 31st Oct 2009, 16:39
