  1. Hi there,
    I read several ways to insert custom subtitles using Virtual Dub and TMPGEnc, in this forum.
    I want to do something diferent, I have the DVD but the DVD doesn't have subtitles in the language I want, but I can get them in the right language from the WEB (.srt file).
    What I want do is the following:
    Use Flask to "provide" the stream to TMPGEnc (using avisynth.dll) and get the subtitles somewhere else (from a "subtitle server ?!?"). Is this possible? Does Flask has any plugin that does this?
    I know I can use Flask and TMPGEnc to get a MPEG file and then follow the guide to insert subtitles in a MPEG file, but this implies coding the mpeg file twice, and this results in a loss of quality.
    Can anyone help me on this one, I know that it's not a usual request but I want to get the best quality I can.
    Thank You
    Luis Pinho
    P.S.: I encode my movies using a 720x576 resolution with 1860 kbps for video and 128/224 kbps for audio (Stereo), 25 fps, I can put about 46 minutes of movies per CD (80 min)
    Feb 2001
    Berlin, Germany
    You can convert the .srt to .ssa and use the VirtualDub subtitler filter.
    http://www.vcdhelp.com/faq.htm
    Since you use Flask, it is probably not easy. Ever considered to use the dvd2avi>VFAPI>VirtualDub(frameserve)>TMPG way?
    However you may be able to use the subtitler filter with Avisynth.
    http://forum.vcdhelp.com/viewtopic.php?t=85367
    If you use the premiere plugin you have to use IPCSource instead of AVISource.
